Author Topic: A question of scale  (Read 1350 times)
Brian60
A question of scale
« on: December 01, 2015, 04:49:43 pm »
I have a plan that is 750mm or (1:114 not a misprint!) in size and I want it at 893mm (1:96) for the ease of getting scale parts for it. Can anyone do the scale conversion please? I've done it and came out with 119% which doesn't seem correct.
nivapilot
  • re-invented rc boater
Re: A question of scale
« Reply #1 on: December 01, 2015, 04:58:59 pm »
"To calculate the percentage increase: First: work out the difference (increase) between the two numbers you are comparing. Then: divide the increase by the original number and multiply the answer by 100"
So 893 - 750 = 143 / 750 = 0.190666666rec x 100 = 19% increase
therefore original dimensions multiplied by 119% = new size..(QED)
« Reply #2 on: December 01, 2015, 05:24:23 pm »
Just divide 114 by 96
Brian60
« Reply #3 on: December 01, 2015, 06:03:57 pm »
Thanks both of you, Niva you have confirmed the answer I came up with using the same formula.  :-)) The end result just looked wrong  :}
Page created in 0.108 seconds with 22 queries.
