Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Dutch Beamtrawler KW88 Pelikaan Scale 1:75  (Read 38512 times)
kees de mol
  • crazy about shipbuilding
« on: December 02, 2015, 09:13:55 pm »
In this buildinglog I will present you the build of the Dutch beamtrawler KW88, Pelikaan.
42,35 x 8,50 x 5,16 mtr
Build in 1999 as the UK 153, Lun Senior, sold in 2007 and named KW88, Pelikaan.
Motor: 2000HP Deutz
The ship has sumwings and uses an electric pulse system The sumwing are like wings and do not touch the bottom. With electric pulse the fish jumps of the bottom and ends in the net.
I started collecting information, photo's and drawings a few months ago and now I am at the point that I can actually start with the build.
I have a complete set of original drawings and almost 500 photo's
It will take some time before I start building this ship because I want to finish the KW49 first.
First some photo's of the ship.
As the UK 153
New registrationnumber
Momentopname%203%206-4-2015%2021-49_zpsx
Groetjes, Kees
kees de mol
Re: Dutch Beamtrawler KW88 Pelikaan Scale 1:75
« Reply #1 on: December 02, 2015, 09:16:00 pm »
Electric pulse system
11117710_693571084102627_677811750_n_zps
Sumwings
Groetjes, Kees
kees de mol
« Reply #2 on: December 02, 2015, 09:16:57 pm »
It was a problem to find any drawings but I found a very helpfull guy who gave me a complete set of original drawings printed in scale 1:75. I am so thankfull!!
Groetjes, Kees
kees de mol
« Reply #3 on: December 02, 2015, 09:17:41 pm »
Hello everybody,
At this moment I have done a lot of work for this model allready. Lots of work will not be vissible when she is ready but is inevitable to get a realistic model. But how good is the feeling when you have (after all the work) a fysical hull in your hands wich look svery good. On the pictures you see the wooden model of the hull. They call this the plug and I will use this in the future to make a polyester mould arround it so I can make multiple hulls out of it. I do this because I want to make two of the same models and maybe I can sell some hull later to other modelbuilders.
The pictures
Here you see a lot of copys of the lineplan to make templates for the longitudinal cross-sections (does that make any sense? I used Google translate so blame them if not.... )
The templates are ready to trace them on the wood
The wood (triplex 3,5mm)
All templates traces on the triplex
The gluing of the longitudinal cross-sections. I pay attention that they are on the correct line and place according the drawings.
And here all the sections together and the top-part glued in places
And then with the help of several powertools and a lot of sanding by hand sanding the shape of the hull. I have to do this very carefull so I wont sand to much. Most of the finishing I do by hand because you have more feeling and it gives a better result.
11377232_674912859319027_687928398686391
(Okay I admit. The sander was not even turned on. My wife made an ACTION-picture. But you can see I lost weigt tough )
It's getting shape
11393198_674913165985663_219205978233720
And then after a lot of sanding and filling (lots of times) you see the result. Its nice and smooth and ready for further finishing.
Thank you for watching, like-ing and reply-ing. The build is on and more updates will follow soon!
Kind regards, Kees
Groetjes, Kees
kees de mol
« Reply #4 on: December 02, 2015, 09:18:23 pm »
I started working on the beamtrawler again. In the summer it's just to hot at the attic so I can't build there. I have done some home improvement instead and build some showcases for a friend.
I sanded the hull and painted her with epoxy and the sanded her again. She has a babyskin now, soft and smooth. I also made a start with the halfround and the spraydeck.
10393830_720561064754206_429113755838707
12003238_721421728001473_446396881293241
Groetjes, Kees
kees de mol
« Reply #5 on: December 02, 2015, 09:19:30 pm »
All halfround is placed now
12004942_723176704492642_385227637179042
Groetjes, Kees
kees de mol
« Reply #6 on: December 02, 2015, 09:20:10 pm »
Added registration numbers and did some other jobs on the hull. Next job will be mould-making for wich I bought polyester and other stuff.
12006269_729634107180235_559454326255334
Groetjes, Kees
kees de mol
« Reply #7 on: December 02, 2015, 09:21:11 pm »
Cooling at the outside of the hul. I also finishes the bowplate and some other things. Just decided to make a keel also before making the moulds. Than every hull will be complete with keel.
Groetjes, Kees
kees de mol
« Reply #8 on: December 02, 2015, 09:30:53 pm »
More work done on the KW88.
Prepare the moulds for laminating. It will be a two part mould. First I will prepare and laminate the first half and after that I will remove the wooden plate and laminate the second half. I have never done this before so it will be exciting. It will take some weeks before I can show the results.
finishing seams with plasticine
waxing. This hase to be done for four times plus polishing
Waxed
And because this will take a lot of time I started to build on the reardecks and the wheelhouse.
Groetjes, Kees
Perkasaman2
« Reply #9 on: December 02, 2015, 10:06:00 pm »
Your work is to  a very high standard. Good luck with the two stage moulding.  :-))
ray123
  • shuswap tugboat
« Reply #10 on: December 02, 2015, 10:39:53 pm »
hi kees  another fantastic build in the making  :-))
kees was there a small beamer model in kit form (cast resin)  i remember seeing it somewhere  have you seen it any where?  regards ray
kees de mol
« Reply #11 on: December 02, 2015, 11:02:39 pm »
Maybe this one? http://www.nautischbureauwoort.nl/viskotter_tx_9.html They will also release a model of the UK 197 a modern beamtrawler
Groetjes, Kees
« Reply #12 on: December 02, 2015, 11:50:27 pm »
Just joining the other responders to say your work is very high standard Kees - hope I can learn some of the techniques you are using.  :-))
BFSMP
« Reply #13 on: December 03, 2015, 10:18:07 am »
What a beautiful ship, and absolutely astounding workmanship.
I can only dream of ever acquiring half the talent to do something like this, but it is fascinating to see how you do such work.
Thank you for showing us all your expertise.
Jim.
ray123
  • shuswap tugboat
« Reply #14 on: December 03, 2015, 05:14:55 pm »
  thats the one  thanks kees  for the link  regards ray
steve mahoney
« Reply #15 on: December 03, 2015, 07:53:09 pm »
I'm enjoying this. Also enjoyed your other builds. Thanks
kees de mol
« Reply #16 on: December 05, 2015, 02:42:40 pm »
Hello Everybody.
Working on the wheelhouse. Lots of work and time but very rewarding.
Groetjes, Kees
kees de mol
« Reply #17 on: December 14, 2015, 09:43:49 pm »
Hello fellow shipbuilders,
Meanwhile I made the roof and the so-called "Pet" and that makes the bridge really complete. It was very hard to find the correct shape and it took me more cardboard and ps plate than I wanted. But at the end it worked out well.
If you look closely you can still see something I've been working on. Something which will be nearly vissible when the model is ready.
Groetjes, Kees
« Reply #18 on: December 14, 2015, 11:28:23 pm »
....Hi Kees, is it the captain in his chair ?
Umi_Ryuzuki
    • Models and Miniatures
« Reply #19 on: December 15, 2015, 12:59:11 am »
Fantastic work, Nice set of plans to work from also.  :-))
Ko Koster built the KW145
kees de mol
« Reply #20 on: December 18, 2015, 08:33:22 pm »
Hello
Thanks for watching my buildingreport and for the support I get from you. Not only in this report but in forum as whole. Your buildings really encourage me to build.
I worked on the Pelikaan again. On the wheelhouse I wanted something to watch at so I started building an interior. It's meanth to be scematic and it is not on scale. But I think it looks good later when you look trough the small windows of the wheelhouse
And I did some work on the hood.
Groetjes, Kees
kees de mol
« Reply #21 on: December 30, 2015, 11:09:26 pm »
not much enthousiasm here.
The winch took me more than 8 hours to build. I want to build more models so I wanted to make resin catings of it
For both materials (silicons and resin) there is an A and a B component. You have to mix them 1:1 and then casting.
I first made a silicon mould which I leave to harden for two days and then I went casting.
Weighing the components on a scale
Then mixing very wel without airbubbles but quick because the resin hardens very fast (2 minutes)
Then casting.
I tried to remove the bubles with a toothpick. Thats works good
Everuthing very fast because the resin hardens very quick. The white glaze is the area where the resin starts to harden
After 30 minutes you can remove the parts from the mould.
After two huors and some sanding I had 3 copies. And some hatches too
I am very satisfied with the endresults. Only the first winch and hatches did need some more attention because I didnt removed the airbubbles the first time. But nothing serious, just some filler and sanding to make them right.
Groetjes, Kees
« Reply #22 on: December 30, 2015, 11:46:18 pm »
Your wheelhouse interior is marvellous. Great build log too.
timbo
« Reply #23 on: December 31, 2015, 09:49:38 am »
Great build :-))
How are you cutting the windows out?
kees de mol
« Reply #24 on: December 31, 2015, 02:39:24 pm »
Great build :-))
In reply 16 there are some pictures of it. I use a homemade millingmachine.
Groetjes, Kees
Pages: [1] 2 3 4 5 6   Go Up
Page created in 0.101 seconds with 21 queries.
