Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: Dutch Beamtrawler KW88 Pelikaan Scale 1:75  (Read 38325 times)
kees de mol
  • crazy about shipbuilding
Re: Dutch Beamtrawler KW88 Pelikaan Scale 1:75
« Reply #25 on: January 02, 2016, 12:03:08 am »
New mould in the making
Groetjes, Kees
kees de mol
« Reply #26 on: January 02, 2016, 03:50:31 pm »
The mould cured well. It's the mould for the collectingbins where the fishermen empty the net in. There are two bins and the skipper can empty them in a central bin from where there is a conveyor-belt to move the fish to the workdeck.
The mould in the making
And its separated. Alle went well and I have a good mould
Here the mould is poured with resin. The left over I poured in another mould so I dont spill any resin
**** I did spill some resin and you can see its curing.
The resin is curred. This takes a few minutes but I wait a hour before I demould the casting.
Demoulding
Drill some holes to let the air in the mould
And here I have another good resin cast. The walls of the bins are 0.3mm thick. Almost no trapped airbubbles so I am very happy.
Groetjes, Kees
« Reply #27 on: January 02, 2016, 07:09:34 pm »
You have been pushing the envelope on resin casting kees! I missed the start of this build but I am glad I found it as the subject is very attractive.
I wish you good luck with your build, I will be following it with interest. Can you show us your milling machine? it looks mighty interesting.
Unsinkable 2
« Reply #28 on: January 03, 2016, 07:42:34 am »
Excellent Kees!
I visited the silicone and more website and was very pleased how much Dutch I can still read.it does me good to keep it up now and again.
Unfortunately with the amount of products I wasn't sure which ones you use to make the silicone moulds! There appears to be different kinds and colours and I'm not sure which to buy to try and do what you did.
 I see  you buy a liquid silicone and a hardner please could you give me some product numbers.
Same for the resin. I just wish to try and make some simple boat features less than 3cm thick for example.
Thanks for any help.   U2
kees de mol
« Reply #29 on: January 03, 2016, 06:55:17 pm »
I use the yellow silicon
http://www.siliconesandmore.nl/nl/products/siliconen-a-transparant-41.html
And the D70 PU resin
http://www.siliconesandmore.nl/nl/products/pu-polyurethaan-gietsysteem-set-d70-snel.html
You can buy it per kilo (500 grams A-component and 500 grams B-component)
Take in mind that the PU-resin has a limited expiration date
Groetjes, Kees
irishcarguy
« Reply #30 on: January 05, 2016, 03:46:04 am »
Kees your work is nothing short of brilliant and an education. I will be following your work & ideas to the end. Thank you so much for sharing your knowledge & expertise so freely, Mick B.
Mick B.
Unsinkable 2
« Reply #31 on: January 05, 2016, 06:52:46 am »
Thanks for that Kees I think I would like to give that a go. I'll be following the rest of this build with interest.
kees de mol
« Reply #32 on: January 08, 2016, 08:03:06 pm »
The chimney has a simple shape at first glance but I got some drawings of it and then you find out its a rather complex shape. There are some curved, round shape which run into each other. And there are some details which form a nice challenge to me.
Posted Image
First I had to build a chimney from polystyreneplate
Posted Image
Posted Image
Posted Image
And then the battery of my camera went dead so no more pictures from the building.
Like the other parts I need more chimneys so I started building a mould. It was hard to find out how I had to do this and I ended up building a 2-part mould from which one part had to cut at one side.
Here one part of the mould is curing. I had to use lots of silicone so with the other part i made some inserts to save on silicones.
Posted Image
Here are the two parts of the mould. You can see the left part has an incision. The parts I place on each other and then I place the red plastic around it to support the mould.
Posted Image
Later I find out that the mould contains some bubbles on some section. These bubbles will be in the castings too so thats a bummer. It is because of the 2-part mouldmaking. Only a vacuummachine can solve this but thats very expensive.
The casting. First I cast the thin upper part with 20grams of resin. With a thootpick I add some resin to the details in the thicker peace to avoid bubbles in the next casting.
After that I cast the thicker part whit 30grams resin and 30grams filler to save on the resin.
And then te results
Posted Image
Some flash but this is very thin and can be removed easily
Posted Image
The place where the bubbles are.
Posted Image
And then in 1,5 hours I got 4
Posted Image
offcourse I will add the details later
Groetjes, Kees
kees de mol
« Reply #33 on: January 14, 2016, 09:07:05 pm »
Here I made a start with the winchhouse. I couldn't build this without the original drawings I got. The polyester hull is also a bit closer to completion but I will post the photo's when I have some more results.
Positioning the parts for the silicon mold
To be continued
Groetjes, Kees
ray123
  • shuswap tugboat
« Reply #34 on: January 14, 2016, 09:17:01 pm »
great work kees  seeing you made a mould's   are you going to make a beam trawler kit?  that would be great if you did  ill  buy one for sure :-)  regards ray
kees de mol
« Reply #35 on: January 15, 2016, 11:40:06 pm »
If I complete the moulds for the hull maybe.
Groetjes, Kees
kees de mol
« Reply #36 on: January 18, 2016, 09:31:20 pm »
I went building on the chimney's. They needed lots of detaills after I had cast them. They are finished for 75% now so I have some work to do yet.
Posted Image
Posted Image
See you with the next up-date
Groetjes, Kees
Unsinkable 2
« Reply #37 on: January 19, 2016, 08:14:59 am »
Hi Kees, great stuff! How many boats are you building?
kees de mol
« Reply #38 on: January 19, 2016, 08:42:37 pm »
At this moment I am building three models. All from the same ship.
Kind regards, Kees
Groetjes, Kees
kees de mol
« Reply #39 on: January 28, 2016, 11:12:27 pm »
I finished the searchlights. Lot of parts and very small to make. I also used the lathe to make some signal lights (the glasses) There are 13 glasses per chimney. I made a toolbit to make the pattern in the clear plastic.
And I made some decals to make the model a little bit more realistic.
Next update i hope to show the finished chimneys
Groetjes, Kees
kees de mol
« Reply #40 on: February 08, 2016, 07:33:11 pm »
Today I did the last things to the polyester mold. I cut all the edges sanded and everything. Then it was time to find out if both halves of the mold wanted to separate. First I very carefully put a chisel between the halves and into the gap I tapped wooden wedges. It took some time and effort but suddenly The first halve separated from the wooden hull and after some tapping the other half released.
I am very happy because it was quite a lot of work and it was very exciting if everything would work the way I wanted.
Here some pictures from begin till now
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Released parts
Posted Image
Posted Image
Posted Image
Posted Image
Groetjes, Kees
kees de mol
« Reply #41 on: February 10, 2016, 09:06:04 pm »
Thank you all for the motivations {:-{
Today I finished the Self Inflatable Liferafts. I remeber my father (who was a fisherman) called them dinkys. It has two plastic shells which are bond together and in between is the liferaft. The liferaft is stored in a steel cage which can be tilted over to release the raft in the sea. In the water the  raft inflates and a rope keeps the raft close to the ship.
A picture of a raft
Soldering the cages
The rafts. I made on to use it as a mould and then I casted more in PU resin.
With some decals
And this is how they will be on the ship. Two rafts on each ship
Kind Regards, Kees
Groetjes, Kees
« Reply #42 on: February 10, 2016, 11:03:07 pm »
Hi Kees, I have just seen your posts. The designer must have been a fine art student at heart as the funnelmast is a work of art. You must have sworn and cheered in equal measures whilst recreating it.
Wether you make it a kit r not, the detail will be fantastic considering the life raft containers and their holders and the searchlights.
Classy work Kees :-))
kees de mol
« Reply #43 on: February 11, 2016, 06:53:46 am »
Thank you. The funnelmast was a challenge but I had the original drawing fortunately. Now the rigging will be a big challenge in the future.
Groetjes, Kees
nivapilot
  • re-invented rc boater
« Reply #44 on: February 11, 2016, 07:38:27 am »
What an inspiration you are Kees, wonderful workmanship.
I love the idea of your homemade router/milling machine....any more details about it?
will be watching this build further, I love the ship, and need some more pushing to get me motivated.
well done Kees.
kees de mol
« Reply #45 on: February 28, 2016, 08:43:09 pm »
Some result so far
Groetjes, Kees
« Reply #46 on: February 28, 2016, 11:16:19 pm »
The hulls look very professional - good work so far. :-))
Dreadnought
« Reply #47 on: February 29, 2016, 04:51:31 pm »
Very nice looking hull you have there  :-) :-)) :-)
kees de mol
« Reply #48 on: March 11, 2016, 10:44:26 pm »
For the trawler I needed a propellor and usually I buy these at the hobbystore but this time I couldnt find what I was looking for and the props I found were expensive (around 15-20 euro's). I need three so it would be a very big gap in my budget.
I looked on the internet for pictures of propellors but there were mostly beautiful new and shiny and thats not the way I wanted them.
And this is the way I like to build and paint them. This ship has fished for two years now before she went in the drydock
12805834_1705828853034018_25790867268313
I started with strips of styreen which I heated and shaped in the right shape. After that I made the shaft with the cuts for the blades
After some glueing I used some Milliput to make a smooth curve from the shaft to the blade. So it looks like a casted one
Here the first paintwork. I used an aluminiumcolour with pigements to get the colour Ik wanted. After this I gave the props a protective coat of varnish
Than I went on painting with oilpaint. I want to weather one prop like its in use for years and the other two will get some lighter weathering.
Groetjes, Kees
kees de mol
« Reply #49 on: March 11, 2016, 10:45:13 pm »
And then the results. I can not capture the right colours in the pictures but I am very content
And I also made some nozzels. I keep the money in the pocket and it gives a good feeling building it myself
Groetjes, Kees
Pages: 1 [2] 3 4 5 6   Go Up
