Author Topic: Australian trawler "Delta"  (Read 11456 times)
B.B
  • B.B
« on: December 17, 2015, 08:19:40 pm »
Hi there, this is the start of the other model I have been building , she is of another trawler from our home port of Brunswick Heads in N.S.W the "Delta" was built in Brunswick Heads around 1972-73 ? her size was 54'  ,so keeping to the same 1:16 scale of 3/4" to 1'  = 40.5"....
1....The middle model is the "Delta" with half her frames erected.
2... Installing the shoulder shelves, this model has a full raise deck.
3...Just checking the fairing of the frames at various areas before planking.
4...Showing her half planked alongside her girlfriend.
5...Adding another plank.
Brian  B
southsteyne2
Re: Australian trawler "Delta"
« Reply #1 on: December 18, 2015, 03:53:09 am »
Hi nice work ,do you have plans for these?
steve mahoney
« Reply #2 on: December 18, 2015, 06:38:55 pm »
Three on the go at once – that's keen.
B.B
  • B.B
« Reply #3 on: December 18, 2015, 08:01:18 pm »
Hi Southsteyne2 ,no set plans to go by would draw them as close as I could to the photos i have (but still have to do adjustments to frames).
Next section of photos.
1...Ribs in the section between frames ready to be glued in after leaving them to set over night after they were steamed.
2...starting on the Merbau timber shelves.
3...Starting to fit the red oak deck beams  3/8" x5/8".
4...All the deck beams fitted.
5...False deck areas cut out and motor pre fitted to shaft.
Brian  B
« Reply #4 on: December 18, 2015, 09:44:02 pm »
You do have some lovely timbers in Australia. Nice work, looking forward to future progress.
B.B
  • B.B
« Reply #5 on: December 22, 2015, 04:54:55 am »
Next photos
1...Showing the motor base.
2-3 & 4... making the beds and frame for the Servo, ESC & TX  units.
5... Both finished beds.
6...Above view of her removable ballast box ,motor base and base for the Servo, ESC & TX .
Brian  B
missyd
« Reply #6 on: December 22, 2015, 06:12:56 am »
Fantastic work!
Danielle
southsteyne2
« Reply #7 on: December 22, 2015, 07:31:00 am »
Great work and enjoying the build process especially the curved decks ,will these have self draining decks?
B.B
  • B.B
« Reply #8 on: December 22, 2015, 10:03:25 am »
Yes John, they have scuppers down along the sides and across the stern.
Brian  B
« Reply #9 on: December 22, 2015, 07:38:57 pm »
I love the servo mounting, it reminds me like Missy D's work of old wooden ships. That is a splendid piece of carpentry.
B.B
  • B.B
« Reply #10 on: December 24, 2015, 09:58:51 pm »
Morning , Merry Christmas .........
1... Pre fitting the 2mm ply deck.
2...sections of the ply deck sitting beside model , as gave the inside of the hull another coat of resin.
3...Ply deck down and start of the wheel house base.
4...Wheel house frames going up.
5... Bottom of the window frames being fitted.....
Brian  B
B.B
  • B.B
« Reply #11 on: December 31, 2015, 03:56:29 am »
Hi there well another year nearly over New years Eve down here, so all the best to everyone where ever you may be....
1, 2 & 3......Side frames of the w-house all up.
4... W-house beams all in.
5...Fitting filler sections between beams.
6...Stern quarter view of the w-house beams.
7...I always like to get my money's worth out of the Plasti bond filler.
Brian  B
Mark T
« Reply #12 on: December 31, 2015, 10:04:57 am »
Another beautiful build Brian - Happy New Year to you and yours  :-)   Oh and if you ever make a set of plans for a Prawn Trawler I'll have a set  :-))
southsteyne2
« Reply #13 on: December 31, 2015, 10:53:34 pm »
Happy new year to you and family plus all you other Mayhemers .
Love your build no kit can match this but maybe a couple hefty bollards on the blunt end ? O0
« Reply #14 on: December 31, 2015, 11:45:40 pm »
Really nice build and I will enjoy following this in the New Year.
Happy New Year
RAAArtyGunner
« Reply #15 on: January 01, 2016, 12:12:19 am »
Brian,
Just a little query, in photo 0488, which shows the rear roof structure, is there any reason why the hip rafter (corner roof support)  is not over the corned stud (post).
It, the hip rafter, also does not dissect the corner angle equally.
Noticed that all the other rafters (roof supports) radiate from the centre one and get extra strength by joining with vertical supports.
Looking good. :-))
bassplayer1
« Reply #16 on: January 01, 2016, 09:52:23 pm »
That is amazing work :-))
B.B
  • B.B
« Reply #17 on: January 04, 2016, 02:47:55 am »
Hi Guys back again, the question you asked Raaartygunner, if the hip rafter you asked about is the one at the front quarter of the w-house, yes it doesn't sit on top of the corner upright stud, as it wouldn't have picked up the side and front roofing edge (that photo is a bit misleading) both sides of those beams had to be trimmed, in the next photo to be put up it shows the beam (hip rafter) shaped to take the side and front corner.
1...Installing the window seals.
2...fitting the false deck areas.
3 & 4...Starting to lay the decking strips ,using Lime wood 5mm x 1.5mm.
5... The last deck strip.
6...Sealing the deck with the first coat of Estapol.
7...The bulwark post ( for both models).
Brian  B
RAAArtyGunner
« Reply #18 on: January 04, 2016, 04:46:05 am »
Brian,
 All  clear now thank you  :-)) :-))
B.B
  • B.B
« Reply #19 on: January 11, 2016, 04:00:15 am »
Hi there back again.
1...Installing the bulwark post (Tasmanian oak).
2...Trimming off the top of the post after the planks attached.
3...Pre fitting the shoulder bollards.
4...Cramping the shoulder sponson's (Tasmanian oak)in a jig after being steamed to let set.
5 & 6...The front raise deck bollard , made from red cedar (sitting in the shed well over 50 yrs).
Brian  B
steve mahoney
« Reply #20 on: January 11, 2016, 07:45:15 pm »
It'll be a shame to cover that beautiful woodwork with paint.
I'm enjoying your builds, you set very high standards.
B.B
  • B.B
« Reply #21 on: January 22, 2016, 10:15:37 am »
Hi back again , thanks for that Steve.
1...shaping the front rope fairleads.
2...hull with it's second coat of undercoat applied.
3...having her under coat prior to her anti fouling.
4 & 5..making the rudder's for both models.
6....Hull's all undercoated.
Brian  B
B.B
  • B.B
« Reply #22 on: January 29, 2016, 01:31:30 am »
hi back again, next section of photos.
1..Shaping the end of the dowels to fit in the construction of the gantries and swing arms.
2...Fabricating the swing arms.
3...A-frame ladder ready to be fitted.
4 & 5..  Start of the hand railing on the front raise deck area.
6.. Soldering the railing into position.....
Brian  B
kees de mol
  • crazy about shipbuilding
« Reply #23 on: January 29, 2016, 11:23:25 am »
Very nice work with the wood.
Groetjes, Kees
B.B
  • B.B
« Reply #24 on: January 31, 2016, 10:06:28 am »
Thanks Kees , next section of photo's.
1...hand railing completed now to clean the excess solder off.
2...Some of the bits n pieces for both models.
3... her Trawl swing arms completed.
4...Showing both the w-house's after their top gear fitted.
5 & 6... W-house on and fitting stays....
Brian  B
Page created in 0.119 seconds with 21 queries.
