Hello, in the limited spare time that I have at this time, I am dedicated to the lighting of Dali.
I had already realized the ceiling lights and halogen spotlights. Now I realized the electronic circuit to the lighting of LEDs and associated wiring. I used the usual Stripboard by electronics and I soldered the wires of the negative pole and the positive pole. To the latter I have inserted for each LED, a 150 ohm resistor to lower the battery voltage (5V) to the rated value of the white LEDs (3V).
Here the spotlight after painting
With another circuit I give voltage to the LEDs of red and green navigation lights of the deckhouse and antenna. The Dali has the distinction of having navigation lights on the four sides of the main deck, having regard to its maneuverability at 360 °
Ciao Ciao
