The chemical reaction going on inside any battery when it is charging is always radically different to the reaction that happens when discharging, so it should come as no surprise that different rates of current are appropriate for the two conditions. While you can get a charge into a battery at a very high rate, it is unlikely to be a full charge, and you are unlikely to be able to repeat it as often as charging at a low rate.
