This is the header post of my build.
Based on Billing Boats BB528 (Smit Nederlands), I have started a modified vessel - sister ship of Smit Nederland - ex-Smit Finland, ex-Finland, now UREKA XIV (St Vincent and Grenadines, Malabo, Morocco), IMO 7800473.
I have started by following the instructions of Billing Boats. Turns out there are different versions of the instructions and the part list. So I have hardly begun, when I have had to interpret, and adopt. That's a lot of fun, however.
I have assembled the Becker rudders out of 29 parts each. I am practicing air brush painting with them (Model Color brass).
The props nozzles are installed into the hull with glue (I am really hoping I chose the correct glue!).
The rudder supports (assembled out of 7 parts each) are installed to the prop nozzles (again, did I choose the correct glue?).
The prop shaft pipe supports are installed into the hull in the right positions (I am most surprised about being able to get them right in one shot!).
The anchor chain pipes are tentatively in position (wondering, where I should cut them...).
I have cut and filed the main deck to fit the hull. Gluing ABS to the plywood of the main deck is my main nightmare right now! I'm feeling, if I mess up with that joint, the whole project in in jeopardy. Today, I found a PU glue that says it's especially good for my purpose.
So, this the status, today.
I have conducted research on glues, paints and other. It seems that in almost every step, I have finally ended up with a sub-optimal solution. I suddenly realise it's good to make notes - why not in this forum, to be sure - so as not to repeate mistakes, or at least avoid some of the extra work that I have already spent, in my next project... Heureka! In following posts, you will find my notes. I am eager to see some feedback!
Ok - next I will study how to post some pictures, here. Hold on a minute...
