Author Topic: GLUES FOR FOAMBOARD  (Read 3975 times)
JIM WORNER
  • Not me chief : Engines
GLUES FOR FOAMBOARD
« on: February 01, 2016, 04:43:33 pm »
Has anyone any experience of gluing foam board?  I am about to assemble some and cannot find any trace of the suppliers recommended glue (STIX ALL).  Ideally one with a fairly short grab time?
Better confess, it will be a small model railway baseboard, but I know where the knowledge will be.
Cheers  Jim W
TheLongBuild
  • Build em, and play hard..
Re: GLUES FOR FOAMBOARD
« Reply #1 on: February 01, 2016, 05:16:27 pm »
Not sure that it is specifically for foam board but I think Model Boat bits do something.
« Reply #2 on: February 01, 2016, 05:18:52 pm »
« Reply #3 on: February 01, 2016, 05:52:59 pm »
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #4 on: February 01, 2016, 06:40:44 pm »
If it's PVC-faced board, I use the 'Poly-Pipe' plumber's plastic pipe glue from Screwfix or Wickes - fast grip/set and you can use it as a filler for small gaps betweein joints.
Robotnik
  • Model Boat Mayhem, it's not too bad
« Reply #5 on: February 01, 2016, 09:05:58 pm »
UHU POR is a foam safe contact adhesive, it glues all sorts of other stuff too.
Klunk
« Reply #6 on: February 02, 2016, 01:02:33 am »
Ok in the UK there are 2 types of foam board.
1. Card faced foam
2. A soft to medium density foam.
If 1 use any glue for paper
If 2 use poyweld/ polypipe
I use the gel version on 2
full time penguin
rickles23
    • Royal Navy Commandos
« Reply #7 on: February 02, 2016, 05:29:35 am »
UHU-POR
An Expanded Polystyrene Glue.
JIM WORNER
« Reply #8 on: February 02, 2016, 09:31:28 am »
Thank you all who answered, looks like Uhu Por gets the vote.
Cheers  Jim
rickles23
« Reply #9 on: February 02, 2016, 01:56:15 pm »
The people who make the foam board recommended Uhu Por.
Crossie
« Reply #10 on: February 02, 2016, 03:28:46 pm »
 Hi rickles,
                for model aircraft I've used UHU Por for many years on depron ( which is foamboard without a card facing) and it is the standard adhesive in aeromodelling circles, though it is best to avoid excess glue outside of the joint as it does not 'sand' well and can be pulled out of the joint.
    A good adhesive to use is epoxy both fast and slow types are okay and will not dissolve the foam and produce a firmer joint. You can also use PVA to glue wooden parts to the card facing. Another foam safe adhesive ,but really only suitable for low strength joints is Copydex.
        Trevor
tonyH
« Reply #11 on: February 02, 2016, 05:15:56 pm »
Another you can use on foam/foam, foam/wood and foam/card joins is NoMoreNails. It's certainly strong enough and the edge sands well if you do get it spreading out of the join. It's also relatively cheap if you need the volume of a cartridge.
JIM WORNER
« Reply #12 on: March 09, 2016, 11:15:42 pm »
Thank you all for your information.  I have now used UHU POR and it seems very effective.
Once again thanks.
Jim W :-))
Page created in 0.219 seconds with 21 queries.
