Author Topic: What can I build that's under 22" long?  (Read 13969 times)
Norman Castle
« on: February 11, 2016, 06:22:14 pm »
I really do enjoy sailing my Springers, but I'm hankering after something with a more conventional hull, so probably a tug or workboat of some kind.   It has to be
a.  No more than 22" long overall (due to transport limitations)
b.  Relatively straightforward to build
c.  Fun to sail
But I'm stuck for ideas, mainly because of the length requirement.  Any suggestions, please chaps?
A positive attitude may not solve all your problems, but with any luck it will annoy enough people to make the effort worthwhile.
Re: What can I build that's under 22" long?
« Reply #1 on: February 11, 2016, 06:26:19 pm »
knoby
« Reply #2 on: February 11, 2016, 06:49:42 pm »
I can recommend John's suggestion of the Swordsman, I run one on a 1000kv brushless,  2s 4000mah lipo which gives me around 40 mins run time & it only ever goes flat out !!  Easy to build & fun to drive.
If you are looking for a tug, then this is good. Hard chine hull & simple balsa construction & the possibility to add as much detail as you wish
http://www.myhobbystore.co.uk/product/17075/tiddler-v104-tug-plan
The path of excess leads to the tower of knowledge
radiojoe
« Reply #3 on: February 11, 2016, 06:50:46 pm »
How about a Clyde Puffer the sea going puffers were 88 feet at 1:48 bang on 22", I believe you can get free plans from Clydebank MBC. :-))
tony52
« Reply #4 on: February 11, 2016, 08:47:40 pm »
I took a look at the Model Boats magazine 2015 special edition and found these Vic Smeed designs still readily available and within your size requirement. Tiddler has already been suggested.
If you fancy a Clyde Puffer as suggested above, Lochinvar at 17" long -
http://www.myhobbystore.co.uk/product/16784/lochinvar-clyde-puffer-paddle-ship-mm1410-plan
Some other suggestions -
Australian tug Yarra at 22"
http://www.myhobbystore.co.uk/product/17060/yarra-mm1346-tug-plan
At 18", tug Bustler -
http://www.myhobbystore.co.uk/product/17039/bustler-mm363-tug-plan
At 21", motor vessel Silver Mist -
http://www.myhobbystore.co.uk/product/16693/silver-mist-mm524
At 21", cabin cruiser Moonmist -
http://www.myhobbystore.co.uk/product/16677/moonmist-mm610
At 20", the recently updated Twinkler design -
http://www.myhobbystore.co.uk/product/323419/twinkler--mm2102
If you don't mind going up to 22.5" Customs and Excise Launch Guardsman, hull also available -
http://www.myhobbystore.co.uk/product/16883/guardsman--plan-mm1330
tsenecal
« Reply #5 on: February 11, 2016, 09:23:54 pm »
midwest made/makes a 22" long 1/16 scale lobster boat.
Subculture
    • Dive-in to Model submarines
« Reply #6 on: February 11, 2016, 11:30:17 pm »
Guardsman by Vic Smeed, nice little custom and excise launch. Can be scratchbuilt from plans or a vac formed hull was available.
Brian60
« Reply #7 on: February 12, 2016, 07:24:02 am »
This was the first boat I scratchbuilt. It makes a beautiful little model and is so simple to build. I was even taking it to work when I was on nights (sat on a very quiet telephone switchboard) and doing it to pass the boredom.
Bob K
  • Bob K
« Reply #8 on: February 12, 2016, 08:43:43 am »
If you would prefer a kit I would highly recommend the new Dean's compact kits.  Most are under 22 inches, and generally 90 to 125 quid.  Everything from tugs to fishing boats, warships to launches.
I have seen HMS Bronnington on the water at our club, and she is really superb.
http://deansmarine.co.uk/shop/index.php/cPath/10_11
inertia
« Reply #9 on: February 12, 2016, 09:02:04 am »
How strange. I thought they had discontinued the 30" version, only to replace it with this smaller one. http://midwestproducts.com/products/maine-lobster-boat
I see however from Midwest's website that both versions appear to be available. http://midwestproducts.com/products/boothbay-lobsterboat
The larger one is possibly the finest wooden kit I have ever built.
DM
TailUK
« Reply #10 on: February 12, 2016, 01:21:38 pm »
A Vintage Model Boat Company  "Wavemaster 25"  Easy to build and customise and  really great on the water.  I've had hours of fun out of mine.  They get "up on the plane" even with a depleted battery.  It's also a vintage classic design which you can take to Vintage Model Boat Shows.
Norman Castle
« Reply #11 on: February 12, 2016, 01:38:17 pm »
Well, I shall be checking out all those ASAP, so thanks once again chaps.  I doubt very much I'd have found those without your help.
Just a couple of points I should have made clear.  One is that I'm into slow-speed sailing on a relatively small pond, and t'other is that it doesn't have to be scale (or indeed prototypical if it's fun to sail).
The 22" limit is a definite limit, by the way, on account of anything longer simply won't fit into my Boat Transport Module a.k.a. the plastic crate on the trailer behind my bike ...
Paul T
« Reply #12 on: February 12, 2016, 02:31:06 pm »
I would recommend Twinkler - MM2102 its a nice little 20in boat that is easy to build and now has the benefit of an easy to follow building article in MB magazine written by Dave 'The Bear' Milbourn.
oh btw Wavemaster 25 is longer than 22in....the clue is in the name
« Reply #13 on: February 12, 2016, 03:26:36 pm »
That name will stick!   O0
« Reply #14 on: February 12, 2016, 03:40:07 pm »
No No not Biffo  %%
Umi_Ryuzuki
    • Models and Miniatures
« Reply #15 on: February 12, 2016, 05:19:08 pm »
Norman Castle
« Reply #16 on: February 12, 2016, 06:31:10 pm »
The mooring tug?
Thank you for that, Umi.  Looks lovely and just the right size but unfortunately well out of my price range  {:-{
inertia
« Reply #17 on: February 12, 2016, 07:24:52 pm »
Pooh? Yogi? Baloo? Fozzie? Paddington? I like this guy best...  (Paul....You're dead meat, dude)
Sorry for hacking your thread, Norman, but this is a matter of honour!
« Reply #18 on: February 12, 2016, 08:47:15 pm »
U-33
  • K-157 Vepr. Akula-11
« Reply #19 on: February 12, 2016, 09:31:28 pm »
Can I make a suggestion? Build a MotorFlote...11" x 8", dead easy to build and transport.
Kipper
  • Bodgitts Dry Dock Co.
« Reply #20 on: February 12, 2016, 10:37:29 pm »
Rich, read the op again, he wants something different to his 'springers', the 'MotorFlote' is not that different.  :-)
Im gonna need a bigger shed.
inertia
« Reply #21 on: February 12, 2016, 11:18:50 pm »
Wrong kind of Bear Mr Milbs.....you more like a care bear
http://www.smythstoys.com/uk/en-gb/toys/fashion-dolls/c-887/care-bears/p-13263/care-bears-sing-along-grumpy/
You're spending too much time looking at toy websites, Stav. I wonder why...
DM
« Reply #22 on: February 12, 2016, 11:56:21 pm »
Yea and comes with free ribbing as well, %) %) %)
Norman Castle
« Reply #23 on: February 13, 2016, 08:38:24 am »
Still investigating those ideas (and a few others kindly suggested to me) and one that's a strong contender at the moment is that Vic Smeed Tiddler.  I'm a bit surprised that there seems to be very little about it on the web by way of build blogs or indeed mentions on forums, so  - am I doing the wrong searches, or is there perhaps a reason why it doesn't seem to be a popular build?
inertia
« Reply #24 on: February 13, 2016, 09:02:13 am »
Norman
By no means finished, but here is a current blog of a 1.5x scale Tiddler.  http://www.modelboats.co.uk/forums/postings.asp?th=102309&p=3
Dave M
Page created in 0.108 seconds with 21 queries.
