Author Topic: Graupner Fischkutter HF-408 Elke - My build  (Read 14838 times)
ProfessorBong
  • Building Graupner HF408
  • First Timer
Re: Graupner Fischkutter HF-408 Elke -- (Newbie Build - Plenty of Questions!)
« Reply #25 on: February 24, 2016, 01:10:57 pm »
Just noticed you have an english copy of the destruction manual
Any chance you could scan and email a copy as mine are only in German
There is a very good chance indeed, give me a couple of days as my scanner is in Loft and its got a NZ plug on! But its no bother as i been meaning to drag it out for some documents i need to scan anyway..
Dont ditch your German instructions though, as the English has no photos, need to read the two together to tie text to photos!
--ProfessorBong--
« Reply #26 on: February 24, 2016, 01:34:28 pm »
Thanks.
Mine was bought as a part started kit (Some trimming of the hull had been done)
Now there's someone doing a build as well its given me the motivation to get started :)
For drilling the holes in ABS I find these save the constant hunting for drill bits
http://www.themodelbasement.co.uk/core-rc-cr235-taper-body-hole-reamer-1-16mm.html
ProfessorBong
  • First Timer
« Reply #27 on: February 26, 2016, 11:55:15 am »
So the postie brought me a collections of Glues today, so i can get stuck in (Pun intended)..
--ProfessorBong--
« Reply #28 on: February 26, 2016, 01:17:20 pm »
Groan!..... Ah well, it is Friday!   ;D
« Reply #29 on: February 26, 2016, 01:46:35 pm »
I feel a bond forming
ProfessorBong
  • First Timer
« Reply #30 on: February 26, 2016, 01:54:54 pm »
Oh dear god what have i done, we are in danger of getting into a sticking sitaution!  :embarrassed:
--ProfessorBong--
« Reply #31 on: February 26, 2016, 01:57:59 pm »
Don't worry we'll stick together and fight them
Hande
  • Dream being fulfilled after 47 years.
« Reply #32 on: February 27, 2016, 04:50:59 pm »
Thanks Kipper
[...] can i ask what glues i need?
So if i am going out buying new glues, what types do i need? The kit obviously is a mix of ABS, Balsa, Ply and Dowel
I don't pretend I'm any sort of expert! I would offer this piece of experience, though: Whenever ABS is involved as either party in the join, PU (Polyurethan) glue is very good. I have heard too many reports about epoxy coming off ABS - even if it seems good right after glueing. Roughening up is essential with ABS (as with almost everything else!). I don't know if there is any other kind, but mine is a two-component product (50/50). To support my choice, it says on the lable that it is especially applicable to ABS.
Trial-and-error doesn't spell failure - right?
ProfessorBong
  • First Timer
Re: Graupner Fischkutter HF-408 Elke - My build
« Reply #33 on: February 27, 2016, 10:55:12 pm »
Thanks for the tip, i brought epoxy so far and will see how i get on. Never used epoxy before anyway, so its all a learning curve! lol
--ProfessorBong--
andrewh
« Reply #34 on: February 29, 2016, 05:50:50 am »
Hi, Prof
Warm welcome to MBM and the build
In answer to a very first question  - to fill holes in ABS you can make an ABS filler goop using a small airtight pot - glass or similar and chucking into it a load of cut-up bits of the ABS (trimmings, sprue bits) and putting in a dollop of the solvent plastic glue*.  Seal and leave overnight and you will have a more-or less runny liquid plastic.  Apply and leave to dry and it  becomes an integral part of the ABS
*like Polyweld or MEK**
**Methyl ethyl Ketone
Note - it also works with styrene, but not foam polystyrene!
Looking forward to the build.  I hope the plethora of adhesive advice has not left you up a gum tree.
(sorry)
andrew
« Reply #35 on: February 29, 2016, 10:54:41 am »
Just adhere to the instructions and you'll be fine
ProfessorBong
  • First Timer
« Reply #36 on: February 29, 2016, 02:21:45 pm »
**like Polyweld or MEK**
Not sure i have anything like that, but i shall look into it!  :-))  Thanks for the tip..
--ProfessorBong--
ProfessorBong
  • First Timer
« Reply #37 on: February 29, 2016, 02:22:28 pm »
Enough! LOL  %)
--ProfessorBong--
