Pages: 1 2 [3] 4   Go Down
Author Topic: Diva scratch build  (Read 21829 times)
radiojoe
Re: Diva scratch build
« Reply #50 on: May 07, 2016, 04:56:48 pm »
Very kind, guys, but I know I tend to use too much solder, anyway I've now done a basic paint job and replaced all the running gear and did the first float test, that was very satisfactory with no leaks, and even with the 4000mah. lipo still needed 160 grams of ballast, I had feared she would sit too low, in which case I would have had to have used a smaller battery, so have to say I 'm very happy with her, and just need to add finishing touches, I intend to keep her basically white with some blue trimming paint.
Captain fizz
« Reply #51 on: May 07, 2016, 05:07:34 pm »
Very nice indeed Joe.
Simon
Starspider
« Reply #52 on: May 07, 2016, 11:46:24 pm »
Nice paint finish Joe  :-))
radiojoe
« Reply #53 on: May 08, 2016, 07:34:03 am »
Thanks guys, I'm quite pleased with the finish considering it's plywood, it did have three coats of primer rubbed down with 800g paper, and five top coats, one and a half 500m cans. %%
« Reply #54 on: May 08, 2016, 10:03:20 am »
That's what I call a  'finish'
Well done Joe.  Excellent work
ken
« Reply #55 on: May 08, 2016, 05:55:37 pm »
Amen. I envy you chaps and the finish you get. I suppose it is mainly elbow grease that does it.
radiojoe
« Reply #56 on: May 08, 2016, 06:35:08 pm »
It's also running round the garage after you've just finished spraying it chasing all the "xxxxxxxx" black fly out. %%  {-)
radiojoe
« Reply #57 on: May 09, 2016, 04:05:41 pm »
Made up a master cleat so I can cast a few, I'm not going to fit too many fittings on her, just the cleats and a bow roller, and maybe some nav lights later, she's more of a fun boat than a display model.
« Reply #58 on: May 09, 2016, 07:53:21 pm »
Hm, it sounds like your painting sessions could become very 'Slap stick' where flies and the like are involved. Just don't swat the fly and then accidently backswat your model leaving a waffle impression in the hull {:-{
radiojoe
« Reply #59 on: May 10, 2016, 03:50:28 pm »
I had thought of making the seats with a foam covered in cloth of some sort but this would no doubt frequently get wet so I simulated them with styrene, I'll have the "upholstery" blue to match the spray rail etc. the boats will have to go on hold for a couple of days, my hot water cylinder sprung a weeping leak, and the new one came today. it's years since I did any plumbing, I've had to clean and oil my steelsons and pipe cutter etc.
« Reply #60 on: May 10, 2016, 07:31:52 pm »
Remember not to use solder paste on this job!
canabus
« Reply #61 on: May 11, 2016, 08:14:00 am »
Another plum job!!!
I finished install a gas hot water unit with two gas bottles and re plumbed the hot and cold pipes, added a shower base and vanity unit!!!
Also re plumbed the drain pipes.
WHAT ARE DAD'S 4!!!!!!!
radiojoe
« Reply #62 on: May 11, 2016, 03:59:01 pm »
Well that's the hot water cylinder done, ;) second time I've renewed this cylinder, first time was about 30 years ago, the cylinder was £80 then, this one was £287, I could have built another boat for that, well nearly. %% %% {-)
radiojoe
« Reply #63 on: May 14, 2016, 02:37:52 pm »
Well apart from maybe fitting some lights, that's Diva finished, a quick but very enjoyable build, apart from the running gear the only item I didn't make was the lifebuoy that I had in the rummage box, so she'll be going for trials next week it will be interesting to see how she performs, I built in enough room for the next size up prop if necessary, but judging by a power up the domestic wet dock she just want's to go, so it looks promising.
Leaky Bottom
« Reply #64 on: May 14, 2016, 04:59:50 pm »
A very nice little sports boat  :-))
Just one little point thou, the bow roller looks far to big and out of proportion for the size of boat
radiojoe
« Reply #65 on: May 14, 2016, 05:18:13 pm »
Yes I think your probably right, it's been bugging me a bit, it's only screwed on I think I'll make a smaller one.
Unsinkable 2
« Reply #66 on: May 14, 2016, 08:03:48 pm »
What a belting boat Joe :-)) . And what a fantastically quick build. Superb, well done!   U2
« Reply #67 on: May 14, 2016, 08:35:42 pm »
She looks excellent and again your detailing really adds that extra pzazz to an already brill model.
The benefit I can see from having a larger roler is that it will be quite strong against the time it bonks off the lake edge a bit too fast >:-o
« Reply #68 on: May 15, 2016, 12:14:02 am »
Another good job well executed - and that detailing on the console adds a nice little touch, nice one Joe. :-))
radiojoe
« Reply #69 on: May 16, 2016, 10:49:47 am »
Thanks guys, I wasn't happy with the bow roller as Leaky Bottom quite rightly pointed out it looked way too big, so I made another about half the size, and although the whole boat is only an approximate scale I'm quite happy with this bow roller.
« Reply #70 on: May 16, 2016, 07:51:16 pm »
Lovely Joe. Nearly done.
« Reply #71 on: May 17, 2016, 10:39:37 am »
Beautifully done Sir.  A pleasure to read your blog.
ken
radiojoe
« Reply #72 on: May 20, 2016, 05:31:49 pm »
Thanks for your comments,    Had her first trials today, when you build a boat from a kit especially a fast boat you can be fairly sure of a known performance, as Diva was scratch built I had no idea how she would perform, of course I knew she would float, go ahead and astern, so it came as a pleasing surprise when she came up on the plane and performed better than I had hoped, even in a fairly strong breeze and quite choppy with spray going over her deck inside remained dry, I took two 4000mah lipo's with me but only used one in a one and a half hour session so quite happy with the run time, although she's fast enough for me I may try the next size up prop as I have built in enough room for it, the motor and ESC get barely warm even at full throttle so for the cost of a plastic prop I give it a go, in the photo's she's at half throttle.
Captain fizz
« Reply #73 on: May 20, 2016, 06:12:50 pm »
Looking very good Joe, well done.
Simon
« Reply #74 on: May 20, 2016, 08:57:33 pm »
Also, you know it is a fun model so you have a bit more leeway if it starts out a bit tender or just pain off balance, whereas your Brocklesby for example, having all that detail and expense, there is the worry about stability and water ingress to consider.
She looks a natural on the water :-))
Pages: 1 2 [3] 4   Go Up
