Author Topic: Type 7 c Engeldive  (Read 3311 times)
Robin smith
Type 7 c Engeldive
« on: May 14, 2016, 08:40:45 am »
Another problem...
In the instruction manual it says:
Ch 1 rudder left and right
Ch 2 Dive planes bow/aft up/down
Ch 3 speed controller fwd/reverse
Ch 4 speed controller fwd/reverse
Ch 5 piston tank fill empty
Ch 6 piston tank fill empty
Ch 7 piston tank fine trim
I have always on my subs had front and rear planes operating independently now it seems this is operating from the same source ie one goes in one direction and the other the other way?
I have a new F16 not got twin stick but I could obtain.
So I have the two sticks at present push forward both could be throttles, left stick left and right could be rudder. Right stick right and left could be fine trim I suppose, I have two sliders which are better deployed on piston tank fill empty.
Any other ideas..I did think about a 3 position switch somewhere?????
tsenecal
Re: Type 7 c Engeldive
« Reply #1 on: May 15, 2016, 03:46:52 am »
i would use a pitch controller on the aft planes connected to the receiver for power only, and bow dive planes on channel 2.
TomHugill
« Reply #2 on: May 16, 2016, 08:21:37 am »
I would get a mixer for the motor channels. You've got 8 channels on that fc-16 so just put the front hydroplanes separately.
Robin smith
« Reply #3 on: May 18, 2016, 07:43:05 pm »
thanks guys for your advice in terms of the mixer what would you recommend and how would this work. Sorry to be thick!
Robin smith
« Reply #4 on: May 30, 2016, 12:05:28 am »
Can someone please advise what a mixer is and where do I get one from ?
« Reply #5 on: May 30, 2016, 02:29:17 am »
Robin......here is a good place to start reading.................although I believe due to space limitations, smaller more subminiature components may be used in submarine applications.....[pardon the pun]................Derek
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwiLmbOw0YDNAhUBp5QKHYtxDicQFggmMAI&url=http%3A%2F%2Fwww.action-electronics.co.uk%2Fmixers.php&usg=AFQjCNEB3xy2QO2H0g7lqhPF8RNRQjQiXA&sig2=vqdnYbTP-ap96WXkxv2KnQ
RMH
« Reply #6 on: May 30, 2016, 08:54:11 am »
Hi Robin
Component shop is the best place to get electronics and they have simple to follow diagrams. Excellent products
http://www.componentshop.co.uk/p40e-marine-motor-mixer.html
Sub driver
« Reply #7 on: May 30, 2016, 10:32:11 am »
Hi
Also for small size mixers ideal for small spaces in submarines check out Mtroniks W and V Tail mixers very easy to use waterproof too and small in size about £15.00  or there abouts they just plug into receiver and servo speedo etc.
www.mtroniks.net
Sub.
Robin smith
« Reply #8 on: June 06, 2016, 08:01:54 pm »
thanks for advice....depressed.
I have nearly finished painting and it looks good. Time to set up and test the tech rack only just got the right crystal fro receive.
Set up left and right stick push forward for forward and back for reverse...works fine
Do you think I can get anything else to work....NO  >:-o  checked all the connections and all ok re read the manual.................. >>:-( so complicated just dont know.
If there is anyone who knows the Engel systems and willing to sort for me I will gladly pay  :-))
Transporting the tech rack not a problem we have family transport company so I can get it most places.Gladly pay!!!!!!!!!!!!!!Its doing my head in  >>:-( >>:-( [size=78%]   [/size]
TomHugill
« Reply #9 on: June 06, 2016, 08:15:39 pm »
Drop me a pm
Page created in 0.12 seconds with 21 queries.
