Author Topic: MFV Serene BRD75  (Read 3127 times)
wbeedie
MFV Serene BRD75
« on: May 19, 2016, 08:49:25 pm »
Inshore potter up on beach for an antifoul and varnish
Re: MFV Serene BRD75
« Reply #1 on: May 19, 2016, 11:01:28 pm »
That photo gives us a fine example of a waterline as it should be - i.e. Straight.
Thank you for sharing.
« Reply #2 on: May 20, 2016, 02:03:27 am »
 :o....the reverse mirror image reflection shows curvature & a draft or waterline can be straight but not in a 3D view  <*<......
Looks like the image was Photoshopped? :o...........Derek
wbeedie
« Reply #3 on: May 20, 2016, 08:28:44 am »
Derek, please do not insult me, there only thing altered there was the colours, and that was just to take the worst of the streetlight glow away, as I hate photoshop and to tell you the truth cant even use it for much more than altering hues and contrasts
wbeedie
« Reply #4 on: May 20, 2016, 08:35:10 am »
THe original picture I think, took about 50
« Reply #5 on: May 20, 2016, 09:41:20 am »
Dear wbeedie..........my comment was an observation only and not intended as a critical comment of your work %)
The original image as posted shows an above water waterline that is near level including the stern, however is a conflict in the image of the reflection ........this 'level' aspect may be some optical quasm as seen in an 'orthographic' view......which is now termed as 3D :-))
wbeedie
« Reply #6 on: May 20, 2016, 09:54:13 am »
To be truthful Derek, my first part of the comment was harsh, but due to the amount of people who rely on photoshop to make a good picture very good in my opinion spoils the art of photography, it has its time and place BUT its not something I use myself unless I stack between 3 and 9 pictures to make a HDR picture which does give depth in field, what probablt gives this picture an unrealistic look is I  was looking down on the boat from the pier, and the harshness of light was dialed down a notch or five as can be seen in the original picture pre cropping, also its a longer exposure, between 6 and 8 seconds which helps flatten the water a bit :-))
wbeedie
« Reply #7 on: May 20, 2016, 09:56:31 am »
Another longer exposure, a bit too long as it has blurred the picture with the boat moving at the hook, both boats owned by same man and have worked on both of them
tugmad
« Reply #8 on: May 20, 2016, 10:29:16 am »
Hi if you look carefully at the picture the waterline IS perfectly straight it is the image that is wrong , it is an optical illusion and it Shows a curve because the image is from underneath the boat and is showing the hull curvature from forward to aft looking upwards.
Page created in 0.088 seconds with 22 queries.
