Logoman,
Have a look at Loctite 243 - I have copied in some description here:
"Loctite 243 - Medium Strength Oil Tolerant Threadlocker 10ml
LOCTITE 243 is a general purpose threadlocker of medium bond strength. This threadlocker secures and seal bolts, nuts and studs to prevent loosening due to vibration. The product works on all metals, including passive substrates such as stainless steel, aluminium and plated surfaces. It is proven to be tolerant of minor contamination due to industrial oils, e.g. engine oils, corrosion prevention oils and cutting fluids. Threadlocking Adhesive - medium strength. General purpose. Suitable for all metal threaded assemblies"
If I remember correctly this is the type I have in my garage. It is a blue liquid and the medium strength formula means that you can be reasonably sure that the thread can be undone again in future if you really need to. With the high strength ones you may never get the thread undone again.
Hope this helps,
Laker
