Pages: [1] 2 3   Go Down
Author Topic: USS Nautilus - final Edition  (Read 17191 times)
Dr.Schmidt
« on: May 27, 2016, 08:10:20 am »
After successful test runs with the prototype, I've decided to incorporate my experiences with it in a second, improve version of the Nautilus. This time it will reach its design waterline and will have a higher battery capacity. I start with a complete set of parts that would also make a kit (in case I do it):
GRPparts: All parts made by glass cloth with epoxy gelcoat as top coat.  Moulds were fabricated based on CNC-milled masters. The parts comprise:
- Bow
- Main hull
- Stern
- Service hatch
- Sail
- all control planes
- rear bulkhead (not depicted)
PVC milled parts: All parts for the inner structure, additional pats and the standCNC milled out of 5 mm and 2 mm PVC:
Brass parts: Photo-etched decks and accessories. 2 x scale brass props custom-made by the PropShop (UK)
Resin parts: Accessories and structure components made from PU resin:
A set of decals with ships number, name, draft marks...
Bought parts:
Engel Modellbau:
1 x Hall sensor for Compact-Tank Controller CTS2 (1585-H05S)
2 x Compression Fittings 2 mm (3289)
1 x Compact-Tank Controller CTS2 12V (1584-CTS2-12)
1 x Piston Tank EA 12V 540 -custom made-  1000 ml (1588-EA-12)
1 x Autoleveler SPC2 (1574)
1 x Pressure Switch 3,0 mm (5029)
2 x ROXXY® BL-Outr. C35-29 500kv 4989 (RO4989)
Hobby-Lobby Modellbau:
10 x Rail posts 11 mm , 3 Durchzüge (910-11)
2 x Standard Wellenanlage , 170 / 125 mm M4 (5000-05)
Conrad:
2 x Roxxy Bruschless-Control 930
Hacker:
1 x TopFuel LiFe 30C 4100mAh 4S (44100451)
Graupner:
2 x Graupner Servo digital DES 47 (7917)
Brüggen:
1 x Bayonet Catch 99 mm x 88 mm
1 x Receiver  Corona RP8D1
And small stuff like bras tubes, rods, connectors.....
TomHugill
Re: USS Nautilus - final Edition
« Reply #1 on: May 27, 2016, 08:35:46 am »
I would love to build one of these so I'm holding out hope you put it into some form of production!
Dr.Schmidt
« Reply #2 on: May 27, 2016, 06:07:53 pm »
  We start with the bow section. Limber holes, deck openings and the holes fort he bow planes have to be defined. The bow planes will be fixed which proved sufficient on the prototype. The bow planes are tilted upwards 30° with respect tot he horizontal. That was not the original state, but during the test runs oft he Nautilus vibrations occurred at the bow planes that disappeared when the planes were tilted 30° upwards. So this was adopted. I work forward along my self-made manual:
Clean the seam with 400-grade sandpaper and flatten the base plane:
Same with the PU resin bow plane mount:
The mount is further hollowed out to reduce its volume above the waterline:
Mark the deck openings, roughly cut them with the diamond wheel and the file it to end dimensions:
I decided to make the limber holes on the lower side closer tot he original (in contrast to the 12 mm hole depicted in the manual). For marking I made a styrene stencil. Drill the holes out with a 1 mm drill and file them to their final shape using a diamond file.
Mark the position oft he bow plane shaft. Here precision is mandatory as precisely positioned shafts make the assembly oft he mount absolutely easy. If everything fits, it’s just a snap together job. Note that the mount was adjusted to the inner contour oft he hull near the seam:
Mark the position fort he slits fort he bow plane mechanics, drill and file:
In the region oft he slits I have removed more material from the mount:
Mark the limber holes with a styrene stencil, drill and file:
Same fort he anchor housing:
Cut the anchor housing according tot he manual -> les volume above the waterline:
Drill vents and the hole for mounting the anchor:
Fit the anchor housing in the bow section:
Glue 1,5 mm diameter brass rods into the anchor housing:
Fix the anchor housing and the bow plane mount with superglue and then use long curing epoxy to make everything rock solid:
Dr.Schmidt
« Reply #3 on: May 28, 2016, 04:13:07 pm »
  The anchor housing has ben glued into the bow with is edge protruding about 0,2 mm above the hull surface. Against this edge one can now easily fill the remaining gaps using polyester putty. After everything is cured, everything is just ground flat using 400-grade sandpaper and wet sanding.
With that the bow section actually would be done. But I have decided to put all those limber holes on the floor oft he bow. This is exactly the place where later lead hast o be positioned for the trimming oft he boat. To prevent blocking of the holes by the lead, I’ve decided to incorporate an intermediate deck. The deck is fabricated from 0,75 thick styrene sheet material and a styrene strip. After fitting the deck into the inner contour oft he bow, it was glued into place using epoxy.
Dr.Schmidt
« Reply #4 on: May 29, 2016, 12:57:45 pm »
  Everything is cured and ground. The bow section is done for now:
Next is the pressure tight section oft he main hull. Again everything is done according to the manual:
First the base planes and seams are again flattened using 400-grade sandpaper:
Then the installation oft he bayonet catch. First the wall thickness oft he main hull ha to be reduced in the area the outer ring oft he catch has to fit. Fort hat one first marks the depth oft he outer ring:
Bubble wrap protects the hull. Then it gets dirty. The wall thickness is reduced using a hand drill and a milling tool. It’s important to take enough time and to work carefully. The bayonet catch is the biggest opening in the hull and therefore has to be fit with maximum precision. In addition, ear protection and dust mask are mandatory for this step. All in all it took me about an hour to complete the milling.
While milling down the wall thickness, occasionally test the fit oft he ring. It hast o slide into the opening without the use of much force.  Additionally I recommend to test fit the bayonet catch inside and outside the hull. There mustn’t be a difference. Otherwise the outer ring sits too tightly in the hull and thereby gets deformed. Clean the milled out section with 180-grade sandpaper and break the edge (so that the ring slides completely into the opening). Then glue the ring into place using slow curing high strength epoxy.
Epoxy residues on the hull and in the ring should be immediately cleaned using acetone and a cloth or Q–tip, respectively.
Dr.Schmidt
« Reply #5 on: June 03, 2016, 02:27:30 pm »
  On it goes with the counterpart oft he bayonet catch in the stern section:
Again the GRP is thinned down until the inner ring fits precisely into it:
The PVC deck support is adjusted and fit in:
Then the bayonet catch is positioned – put together and mark the position. Turn the inner ring until the catch can again be released – second marking. The middle bewteen these to marks is the locked position of the catch. Fix the inner ring in this position with adhesive tape.
Put the stern section on the inner ring, adjust its position, and fix it with epoxy.
The deck support is glued into position:
When everything I cured, fill the remaining gaps between inner ring, stern section and deck support with thickened resin or epoxy:
On the main hull, glue the resin adapter into position:
The bearings for the stern plane axles are cut out of 4 mm x 3 mm brass tubing (4 pieces, 5 mm length each):
The bearings are glued into their seats using epoxy. Remove excess epoxy using a clot and acetone. Check the bearings with a 3 mm brass axle. Because of the CNC–based fabrication of the GRP parts, the position of the bearings should be on spot without the need for adjustment:
Dr.Schmidt
« Reply #6 on: June 03, 2016, 04:52:05 pm »
Installation oft he stern tubes is quite simple:
I use standard stern tubes, 170 / 125 mm M4 mit 6mm outer diameter  from Hobby-Lobby-Modellbau.
The surface of the tubes are sanded with 180-grade sandpaper and then put into the tube tunnels in the stern section. They should slide easily into the tunnels. If not – more sanding. The inner edge of the service hatch rim is trimmed so that the set collars have enough space.
The stern tubes are pushed far enough into the tunnels so that the hex nut of the of the propeller axle are hidden in the stern wings:
When everything fits, the tubes are fixed using superglue and then reinforced using epoxy:
Dr.Schmidt
« Reply #7 on: June 04, 2016, 05:22:29 pm »
  Fitting of the service hatch. Again lots of grinding using a Dremel and 180-grade sandpaper. When the hatch is mounted, the remaining seam must be minimal.
Then, the deck opening in the stern section is marked and cut using a diamond wheel and file.
The opening can now be used to check and optimize the glued interface of the bayonet ring.
Next is the inner structure, which is made of two parts. The first section which is mounted on the rear bulkhead and the following mains section.
One starts with the first section. On the snap together components, the round milled contours of the PVC parts are filed to 90° angels.
The holes in the GRP rear bulkhead are opened and the section of that will be glued together are sanded with 180-grade sandpaper.
The servo board and its support are glued together using PVC glue:
The holes for the servo fixtures are countersunk:
The cured servo board is glued to the next bulkhead in a 90° angle using again PVC glue.
With the brass tubes for the thread rod and the water supply the whole assembly can preliminary be put together.
M4 stainless steel thread roads are cut to length:
The thread roads are thoroughly cleaned and the corresponding stainless hex nuts are cleaned and sanded. Then the thread roads are glued watertight into the rear bulkhead using epoxy. The whole assembly is still just preliminary put together.
Dr.Schmidt
« Reply #8 on: June 05, 2016, 04:58:21 pm »
  After the thread rods are fixed in the rear bulkhead, the whole segment can be glued (epoxy) and screwed  together. The position of the hex nuts can be used to fine-tune the position of the PVC structure:
Also the service hatch needs some limber holes for the flooding of the stern section. Mark the centerline: Mark the contour and centerline on a board. Then transfer the position of the centerline using a right angel:
The limber holes are marked using the stencil fabricated for the bow section:
Then drill and file:
Dr.Schmidt
« Reply #9 on: June 07, 2016, 07:55:19 pm »
  To finalize the first interior section, the tube fort he thread rod oft he piston tank is glued shut with the resin pug. In addition the connectors fort he rubber bellows fort he push rods (Engel-Modellbau) are glued into position:
Then the plug-in mounts of the service hatch are installed. I use aluminum pins and sockets originally intended to be used for moulds, but brass pins and sockets are equally suited:
The position of the pins is marked on the edge of the stern section, drilled and filed. The pins are the preliminarily fixed using superglue:
Then the pins are finally glued into place using again epoxy:
The positions for the sockets are marked on the hatch, drilled and filed:
The pins are treated with a release agent (Polyvinyl alcohol), the sockets put on, the hatch installed and fixed with adhesive tape:
Then the sockets are glued into place using epoxy:
Robin smith
« Reply #10 on: June 08, 2016, 11:30:55 am »
Are you going to supply this kit complete and with dive system? I like it looks good. Regards Robin
Dr.Schmidt
« Reply #11 on: June 08, 2016, 09:42:24 pm »
No....the dive system is based on a standard Engel piston tank. No need to invent anything new here.
Dr.Schmidt
« Reply #12 on: June 10, 2016, 07:57:37 pm »
  To fit the service hatch to the bayonet ring, the ring and the adjacent GRP parts have been treated with release agent. Then thickened resin was added to the inner rim of the hatch and everything put together. Through the still open bayonet ring excess resin can be removed. When everything is cured, disassemble, clean the seams and the fit is done:
The battery support is made of four milled PVC parts. Again, remove the milling radius at the positions where parts are put together. To assemble the two half bulkheads, four 4 mm diameter studs were made, that help to perfectly align the two bulkheads. Assemble using PVC glue:
The battery support board is glued to the bulkhead in a right angle:
Dr.Schmidt
« Reply #13 on: June 11, 2016, 12:12:37 pm »
  After fitting the service hatch, the first section of the inner structure can be glued into the stern section. In particular, the motor bulkhead has to be glued into the inner ring of the bayonet catch. Actually that is simpler than it might seem. The watertight motor feedthroughs are put into the holes of the motor bulkhead and locked. I use my custom-made ones from the prototype:
Because of the v-shape of the motor bulkhead and the position of the motors, the propeller shafts and the motor shafts are perfectly collinear when the bulkhead is correctly positioned. To reach this alignment, I fabricated two auxiliary tools.  They are basically 4 mm brass tubes put into 5 mm brass tubes. The tubes are glued or soldered together. The 4 mm tube is put onto the 3 mm propeller shaft, then the 4 mm motor shafts are put into the 5 mm end of the tool until everything sits loosely. The motor bulkhead is in the right position.
The inner ring of the bayonet catch and the motor bulkhead are sanded with coarse sandpaper and then cleaned with acetone. A generous amount of extreme-strength epoxy is put into the middle of the inner ring. Then put the motor bulkhead into the ring using the auxiliary tools. Check if everything is positioned correctly, then let thoroughly cure everything.
Dr.Schmidt
« Reply #14 on: June 15, 2016, 09:46:11 pm »
  Next is the second part of the inner structure. Three M4 stainless steel thread rods are screwed into the last bulkhead of the first section. The nuts are secured using superglue:
In the first support bulkhead for the piston tank the hole for the water hose is drilled wider to 9 mm diameter:
Then the support bulkhead is secured in the right position using M4 stainless steel nuts, which are again secured using superglue. It is important to adjust a constant distance between the bulkheads to ensure that the support and the thread roads are correctly positioned and aligned:
In the forward battery support bulkhead, recesses for the metal bends and their supporting screws are machined. The bulkhead has to fit tight against the bulkhead:
In the first support bulkhead recesses for the metal bands of the piston tank are machined as well:
The battery support bulkhead is secured in the correct position using M4 nuts, which are again secured suing superglue:
With this, the inner structure is basically done and the position of the piston tank well defined:
Dr.Schmidt
« Reply #15 on: June 18, 2016, 05:09:43 pm »
  The fastening of the service hatch is done with three M2 screws. The position of the screws are marked on the hatch ( 2 x under 45° on the bow side and one in the middle on the stern side). The 2 mm holes are drilled.
The hatch is attached and the bow holes transferred into the bayonet ring. The holes in the ring are widened to 3 mm diameter and M2 brass thread insets are glued into them. For this, the screws are first treated with release wax:
The thread insets are available from china in 20 piece packaged for 3€ on eBay. The bow fixture is done:
The stern position of the hole is transferred onto the sterns section:
A support strut is cut from 5 mm GRP plate material:
The strut is fit into the stern section:
The support I glued into place, the 2 mm hole in the hatch is transferred into the strut, widened to 3 mm diameter and a thread inset glued into it:
With that, the stern fixture of the hatch is done, too:
To secure the piston tank a bracket with a 2 mm hole is fabricated form 1 mm brass sheet. With the tank in place, the bracket is fixed using superglue:
The position of the 2 mm hole is transferred onto the battery support, widened to 3 mm and again a thread inset installed. In the soft PVC it can be punched into place.
With a M2 screw, the tank now can be secured:
Navy2000
« Reply #16 on: June 19, 2016, 03:11:16 pm »
Looks like a well thought out plan for the build. Great job you are doing.
Duane
Dr.Schmidt
« Reply #17 on: June 20, 2016, 09:39:26 am »
Thanks.....there went allot of time into the design and tool making for this boat. Now I just enjoy how everything comes together.
Cheers Andreas
Dr.Schmidt
« Reply #18 on: June 20, 2016, 09:36:25 pm »
  Next, the bow section is glued to the pressure-tight main hull. Sand and clean the adherent and fix both parts using high-strength epoxy. The bow deck is used to align the two sections but mustn’t be glued yet.
With that the main hull is complete:
To support the photo-etched deck and to mount the sail, struts, fabricated from 2 mm GRP sheet material, are fabricated and glued into the associated recesses in the main hull:
Again remove epoxy residues using a soft cloth and acetone. The deck is put onto the hull to check for the correct position f the struts but mustn’t be glued yet.
Side remark:
The photo-etched deck is best removed from its sheet using a Dremel drill with a small cutting disk.  Carefully clean the edges using fine grade sandpaper.
Dr.Schmidt
« Reply #19 on: June 23, 2016, 10:32:03 pm »
  Put together it starts looking like a boat. Now it gets dirty: Grinding, filling seams and gaps, again grinding. What one invests here in time, care and sweat will pay off twice when the first layer of primer is applied.
Dr.Schmidt
« Reply #20 on: June 27, 2016, 09:22:12 pm »
  A few hours later: The whole boat is wet sanded and where necessary, the contours are corrected using 2-komponent polyester putty (usually used for cars). To get the seam of the service hatch as narrow as possible, the hatch is treated with release agent (PVA), putty is applied to the cut for the hatch, and then the hatch is pressed into the soft putty and fixed using the M2 screws. Wet sanding (400 grade sandpaper) and the fit is close to being seamless.
The final part that goes onto the hull is the sonar dome. It is made of two cast PU resin parts.
Clean both parts and glue them together (superglue):
The deck is put onto the hull, adjusted and then the sonar dome is glued to the hull where its position is marked on the deck. Don’t fix the deck yet.
Fill the seam, sand it, done:
Next the hull can receive its base coat.
The sail (GRP) is cleaned and sanded with 600 grade sandpaper before further assembly steps can be started:
Dr.Schmidt
« Reply #21 on: July 01, 2016, 10:26:56 pm »
  First the viewports in the sail have to be defined. Nautilus had three levels of these viewports and at 1:87 scale they are actually only 3 x 4 mm large and are separated by only 0.5 mm minimum. The easy approach would be to just paint them on. I decided to cut them out. Mark, drill, file:
For the marking masking tape is a good choice as it can easily be corrected until everything is in the right position:
Centrally under the lowest viewport level a resin detail is fit into a 5 mm diameter drilling. Glue it into place, filling, sanding, done:
Dr.Schmidt
« Reply #22 on: July 03, 2016, 04:01:24 pm »
  On it goes with the sail, mast support and bridge assembly:
On the upper rear edge of the sail the fin (photo etched part) is inserted:
The position is marked with masking band end edding and a slit is cut free using a 0,3 mm drill:
The fin is glued into position, the seams filled and sanded flush:
In the area of the bridge the inner edge of the sail has to be removed using Drehmel tool and diamond files. The bridge has to sit flush.
The mast support is a big resin cast part. To reduce its volume, not needed sections are marked and removed using saw and files.
The underside of the sail deck is sanded planar and the seams are cleaned:
The mast support is glued to the underside of the sail deck. Watch for exact positioning:
3 mm diameter vent holes are then drilled into the mast support.
Test fit and set back the inner edge of the sail if needed:
The bridge is a resin cast part. It still need compass repeater and rudder indicator, which are also resin cast parts.
The compass repeater is made of two parts – housing and lid. Both are sanded planar and cleaned. Glue them together using superglue and drill a 0,5 mm diameter hole horizontally through the housing:
Drill a 1 mm diameter hole in the marked position of the bridge deck:
The bracket for the compass repeater is a photo-etched part. Cut free, clean the seams and sand it using 600-grade sandpaper. The bend the wings into right angles using tweezers:
Put everything together with a 0,5 mm brass bolt and fix it with superglue:
Put the compass repeater it into the bridge using a 1 mm brass wire and fix with superglue:
The rudder indicator is again sanded pkanar and glued into position using superglue.
Then the bridge assembly is glue to the underside of the sail deck. Test fit the whole assembly into the sail and make adjustments where necessary.
When everything fits, glue the deck assembly to the top of the ail using epoxy:
Dr.Schmidt
« Reply #23 on: July 19, 2016, 05:05:05 pm »
   After everything has been glued into place, fill and sand. Then all parts have to be prepared for the base coat. All surfaces are wet sanded with 600-grade sandpaper. This also includes the control planes.
When everything is sanded, all surfaces are thoroughly cleaned of dust and then degreased using silicone remover.
The parts that mustn’t be painted are masked suing masking tape. Then all parts are fixed for the painting using auxiliary mounts.
I use Südwest Allgrund 2-component filler/primer for the base coat, which I mix with 15% thinner (long). I apply the coat using a Satajet B (1,35 mm nozzle). It is important to thoroughly clean the room in which the paint is applied (here a garage) from dust and to clean all surfaces near the parts that are going to be painted using a wet cloth. The we are ready to go. Important: Use a breathing mask!!! Here the result:
Now the remaining micro pores can be filled and then again everything is wet sanded using 600-grade sandpaper.
Dr.Schmidt
« Reply #24 on: July 21, 2016, 01:36:18 pm »
  The sail has been sanded down wet using 600-grade sandpaper. Now the surface details can be applied. First the handrails:
One needs 0,3 mm diameter spring steel wire, 0,5 mm diameter rail posts and a 0,5 mm diameter drill bit:
I chose rail posts for three rails. The holes for the rails are 0,4 mm diameter:
The 0,5 mm diameter holes are drilled into the sail at the already marked positions:
The rail posts are cut into single rail posts:
The heads of these single rail posts are filed flush (good needle-nose pliers, needle files, 600-grade sandpaper and lots of patience!). Then the single posts are threaded onto the steel wire. The wire is angled 90° at one end:
Then everything is put into the respective holes, while 0,5 mm thick styrene sheets serve as spacers:
Fix everything using masking tape:
Now everything can easily be glued into place using superglue (apply glue to the posts and the connections of the wire with the posts. Remove the spacers and cut the wire flush with the last post in the front:
Same on the other side, just one rail post less:
Pages: [1] 2 3   Go Up
Page created in 0.12 seconds with 22 queries.
