Years back when I was doing a lot of patternmaking for my model railway business, I used MEK ( Methyl Ethyl Ketone ) by the litre, in steel cans, then I started to get chronic headaches and did some research!
Not good! This stuff is also quite dangerous, and I had to put in a dedicated fume extraction system to scavenge the air from directly in front of my patternmaking work bench to remove the fumes. The suction tube actually sat on the bench directly in front of where the workpiece was, so any fumes from the MEK went directly outdoors.
One of the "thought to be safer" adhesives for HIPS or white styrene is Limonene, which is a natural extract from lemon skins, or so I was led to believe, but when you check the MSDS you get all the same warnings as you do for other known nasties, so maybe nothing is safe to use without all the safety gear in place. It's also a fire hazard with quite a low flashpoint of 48 degrees C!
I suppose for old modellers who are close to the end, it doesn't matter so much, but for the younger ones, you need to stay healthy longer!
Back to Plywood and Aliphatic Resin, but then some of these resins have Isocyanates, and that's about as dangerous as you can get!
Maybe knitting? or Lawn Bowls!
