Dave (Stavros) and Barry (Footski) have asked to see some photos of my 00 gauge railway layout, which is under reconstruction, so don't laugh at my efforts
I became interested in British outline model railways nearly 55 years ago, soon after our oldest son was born. I bought him a Triang Princess Royal loco, a couple of carriages and some track, which we used to lay on the lounge room carpet. I progressed to a rudimentary fixed layout under our house, however he lost interest in the railway, but I carried on. 12 years later we moved to our farm, and the layout was dismantled and stored until, in 1994, we moved to the sea side. I then built a new layout in the garage which had to be suspended from the ceiling to allow the car in. I welded up a sort of truss girder arrangement with the main baseboard screwed to it, and used a small boat trailer winch to raise and lower it. It was a continuous run around the garage with other sections attached to the walls, and one fixed board on a cupboard. It was rather fiddly to set up, but it was in constant use until we moved back to the farm in March 2012. The layout was again dismantled, and about 2 years ago I decided to rebuild it as a permanent layout in our 40' x 12' farm shed. I had to leave at least half of the shed for farm stuff, so the layout occupies some of the other half.
It is now an end to end layout, representing a fictitious preserved railway somewhere in England. This means that I can use clean locos and rolling stock rather than weathering them, and I try to use models of locos that are currently in preservation. Because it is fictitious I can cheat a bit if I want to
Some of the locos and carriages are quite old, although all the carriages have had their plastic wheels replaced with Bachmann wheelsets for smoother running. I had an old H & M Duette controller, but this has recently been replaced by a new Gaugemaster twin unit, as some of the newer locos were too jerky at starting with the H & M. Some buildings are by Superquick but the majority are printable downloads from Scalescenes and Justin Noble.
The photos show how I've covered the main baseboards to protect it from dust and rodents, which can be a problem in a farm environment. The clutter in the shed is all my own work, but at least I know where everything is
The layout is operational, but much needs to be done yet. All the wiring, which is analogue - I haven't ventured into DCC - works as it should, and running is usually fault free, provided the track is kept clean.
One turntable is an ancient Triang electrically powered unit, the other is a new Peco example mechanically operated by a hand crank and Meccano gears. I have had a lot of fun building to the stage I'm at but, as I said before, much more work lies ahead.
Peter.
