I am now in the process of starting to construct an oil separator/condenser. The size is approx. 30 mm dia x 70 mm.
Can anyone recommend the max/min dimension from the bottom of the 'discharge' pipe to the top of the base so as to allow easy discharge of the 'sludge'.
Should the bottom of the discharge pipe be square or would it be preferable to be cut at an angle?
Roger
