Thanks for the comments chaps.
A start has been made on the 1/12th version.
First thing needed was a rigid chassis.
This was followed by the main barrel that holds the engine and hydraulic compressor.
The two have been temporarily fixed together and the main pivots for the outer drive units added.
The recessed door was fabricated from 2mm styrene. The dished section was heat formed and glued into the outer ring and when hardened off given a coat of primer.
The drivers compartment has been fabricated using the same tubing from the body and styrene sheet.
The windows and door have been cut out and then given coats of primer and orange topcoat.
The drivers seat has been made and a much modified figure added to do the driving. This will sit on its pivot in the cabin later when the interior is finished.
