hi no thats true,,,,,bot i have 2 off them and some other kind to,,,and they just work perfect,,,cut of with 60-or 70 psi,,,even the gastank get hot,,,it is close to the burner,,
bot so there is this
http://www.dampfmodellbau-keifler.de/ Artikelnummer: 14-4000/S
Especially suitable for steam model boats
If required by small little steam ride is needed, the boiler pressure rises, so inevitably the pressure relief valve that Überduck abbläst. But the gas burner system RV 3 with RGD 3 is used, the effect of increasing pressure on the RGD 3 and thereby continuously reduced the gas flow through slowly to the set minimum value down. The flame will be smaller and produces less steam pressure.
If the machine again consumed drops of steam boilers and pressure from the control valve automatically opens the Gaszufuhrventil.
The vapor pressure should not drop below 2.2 bar and 3.0 bar not exceed, with the mean pressure at 2.6 bar.
This combined rule automatic saves gas and water, then extended the Duration and thus contributes to the optimum driving at. The use of such a valve is recommended for all types Brennero.
The compact body normally consists of two interconnected screwed valve blocks, the RV 3 and RGD 3 By the Gasreduzierventil RV 3, the pressure in the Gaskartusche which could. That means that once recruited for the gas burner is full, as well as almost equally empty cartridge. Under a scheme due to pressure in the Gaskartusche deleted. The print cartridges before the RV 3 can be up to 5 bars; a precise setting of the gas pressure of 0,1-1,2 bar with the upper adjuster infinitely possible. In addition, the housing is a second connecting thread for the reduced pressure. Published after the closure screw bolts can be a pressure gauge for testing or setting can be connected. Nor can this connection for a pilot flame of the burner used. Is a Gasreduzierventil exist in a gas cylinder may be based on the RV 3, where appropriate, be waived.
When ordering the fluent regulation you need to expect longer delivery times!
