Author Topic: How heavy will it finally need to be?  (Read 1548 times)
Ship Worm
« on: October 08, 2016, 11:08:44 am »
If you are just starting out with a kit which has a blown or fibreglass hull, simply mark where the water line is on the inside of the hull, get a spirit level to make sure everything is level and fill with water to the water line marks. The number of litres of water is equal to kilograms and ignoring the actual weight of the hull itself will give you a pretty good idea of how much ballast (or goodies) you can have/or will need.
Once its finished and on the water you will then only need to finally tweek the weight to ensure the trim is correct.
NEVER EVER permanently secure ballast weight or big Lead Acid batteries that cannot later be moved a bit - or you could have a boat that is stern or bow heavy and cannot be trimmed properly, when all the internals are fitted.
I may be getting older - but I refuse to grow up!
Re: How heavy will it finally need to be?
« Reply #1 on: October 08, 2016, 11:46:38 am »
Top advice.  :-))
Page created in 0.11 seconds with 21 queries.
