Here is a poser then. I had the good fortune to work on a R2D2 prop, that was surplus to the effects companies needs, and was passed on to a private collector. It had to have been laid up, if not constructed during the nineties as a display piece, in GRP. It had been assembled with what looked outwardly like standard car filler, big blobs of it and off white, with a filler feel to it. However, it was absolutely rock hard. I was unable to chisel it off as you would expect to be able to do with standard filler. I would say it had the strength of an epoxy putty like Milliput, rather than the easy sand or carve finish of normal filler, which it outwardly resembled..any thoughts?
