Hullo Jim......[& the 4 legged family
].......all is not lost, however some serious work will be required
You must define the hull material......[expanded styrene? .....fibreglass????]
You must ensure that the repair process will eliminate the full profile of the crack within the parent material
Full scale engineering repair processes will be required
If the individual cracks do not protrude into the inner hull, this is only a visual assumption.......
The following is only
one method of stitch welding as a reclamation method to provide a totally sound mechanical hull surface & section
1.Find the visual starting point of a crack on the outside of the hull...drill a 1/16" diameter hole right through the hull
2. Repeat this at the other end of the crack
3.Depending on the length of the crack, drill the same 1/16" diameter holes at say a nominal 1/2" spacing
4.With a
V shaped scraper, chase the crack on the outer hull until approx. 1/2 of the hull thickness
5. Repeat this on each & every external visual crack....
6. Repeat the steps 4. & 5. from the inside of the hull, until you are confident that the inside & outside V scrapings are
near to joining
7. The area surface adjoining each crack will need preparation to be completed in accordance with the actual hull material
8. Mask with PVC tape the length of each individual internal chased crack
9. invert the hull and flood the viscous liquid/paste repair medium.......
10. Repeat the process as at 10. on the internal sections of chased crack
In reality you need to ensure that the hardness of the 'welding fluid' is similar or the same as the hull. This will ensure minimal surface removal of the hull material when completing the surface sanding process
Good luck..........Derek
