Author Topic: Fish Trawler "Meili-Lady"  (Read 11394 times)
B.B
  • B.B
Re: Fish Trawler "Meili-Lady"
« Reply #25 on: December 29, 2016, 07:08:00 am »
Hi there thanks Alan.
1 & 2  .. W-house before and after the beams installed.
3 & 4  ..braces for the eyebrow fitted and remaining of the top trimming finished.
5 & 6  ..The main base for the radar,satelite frame.
7  .. Top lift out section of the radar ,satelite frame.
8  ..Radar & satelite frame finnished , couldn't find any thing suitable to make the sat domes from so made from timber ,then I seen some shots of a deodorant lid utilized for the dome ( gees why didn't i think of that :(  ) next time :).
Brian  B
mike_victoriabc
« Reply #26 on: December 29, 2016, 11:24:36 pm »
Amazing detail - do you rip all your own wood strips?
Thanks for posting the building steps.
B.B
  • B.B
« Reply #27 on: December 30, 2016, 04:02:16 am »
 Hi Mike, with the planking strips (bit lazy there) I buy those generally from 'Modellers Shipyard' in Australia found them to have very good quality lime wood ,have bought some from the UK but found the lime wood strips very splintery and softer, all the other deck beams etc cut those on the band saw.
With this set of photos are of 2 crane kits i bought from the UK, one from 'Model Slipway' a power block crane FK-OL ,even though this kit is scale of 1:24  and my models are of 1:16 I wouldn't want this any larger, and the second crane kit is from 'Macs Mouldings' a Seacrane M321, I made some slight modifications on them but very impressed with their realism and outcome of both of them.
With the aft power block crane i made a slide frame on the trawl gantry to make it easier to remove etc.
Brian  B
B.B
  • B.B
« Reply #28 on: January 02, 2017, 10:26:04 pm »
Morning , next section of the build.
1 & 2 ...The front mast base, can easily dismantle mast from base.
3  ...The frame for emptying the cod end .
4  ...Showing most of the bits n pieces where they will live.
5 & 6  ...Hatchway to the top of the w-house ( solder still to be cleaned around the joints of hand railing ).
Brian  B
B.B
  • B.B
« Reply #29 on: January 07, 2017, 02:49:46 am »
Hi there, next up the hand railings around her, tried something different this time, with the main up right post I driled them on a slight angle to suit the lighter cross rails ( looks a bit rough how I drilled them out), broke the drill bit a few times ,had just enough of the bit left to finish the job off, once they were all in position then soldered all those sections......
Brian  B
Spinner
« Reply #30 on: January 07, 2017, 03:34:56 am »
Beautiful work Brian  :-)) :-))
B.B
  • B.B
« Reply #31 on: January 07, 2017, 10:23:31 pm »
Thanks Spinner, these are the last shots of her before packing her up to take them south , did the final assembling there.
1 & 2  .. Made a couple of trawl blocks from fittings I scavenged from something about 20 yrs ago (can't remember what the hell it was ???) I generally have a container I keep all those little goodies in for use .
3  ...She is just hanging around while her bottom drys ,sprayed her bottom all the remainder brushed.
4  ..Showing her inside with the R.C gear installed ,so plenty of room in her for ballast.
5  ..With all her vinyl strips attached (sure does beat trying to paint them)
6  .. Sticking her windows in I just use P.V.A wood glue......
Brian  B
« Reply #32 on: January 08, 2017, 06:35:33 pm »
Is the double U piece in your last photo a jig or just a useful retainer to hold the window frames straight while the glue dries???
Mark T
« Reply #33 on: January 08, 2017, 06:52:38 pm »
Is it a cut in half chain link?
B.B
  • B.B
« Reply #34 on: January 09, 2017, 09:29:31 am »
Hi guys, yep they are just cut up s.s chain links ,just using them for slight weight while the glue dries.
Brian  B
B.B
  • B.B
« Reply #35 on: January 21, 2017, 03:59:46 am »
Hi there ,well bubble wrapped the bulk of the models in the photo and we transported them from Cairns down to Byron Bay prior to Christmas,and finally has her name and numbers attached.
I named her after my wife Catherine (I couldn't use "Lady-Catherine" as Peter has a lovely model with this name) Meili ( pronounced  May Lee in Chinese  is Beautiful ).
we gave her a float and ballast test the other day, there are 2 photo's of her sitting as she is and the others after installing the ballast she took 3.860 kg towards the bow and 3.790 kg in the hollow heel area total of 7.650 kg, and the last photo showing Catherine with the model....
Brian  B
B.B
  • B.B
« Reply #36 on: January 21, 2017, 04:05:26 am »
Hi There, some more close up shots of her, also checked her R.C gear out to make sure every thing running the right way ........
Brian  B
missyd
« Reply #37 on: January 21, 2017, 07:00:03 am »
 :-)) :-)) WONDERFUL model!!!!  :-)) :-))
Danielle
Joinerman
« Reply #38 on: January 21, 2017, 08:28:18 am »
Stunning workmanship reflected in the final ship which looks fantastic.  :-)) :-)) :-)) :-)) :-)) :-)) :-))
« Reply #39 on: January 21, 2017, 06:07:09 pm »
Wow!!!! It is not often you can say that a model is as beautiful inside as it is out knowing the quality of your carpentry in making the hull.
Lovely!
desktoprover
« Reply #40 on: January 21, 2017, 06:40:55 pm »
Fantastic work!  The crane is just awesome!
B.B
  • B.B
« Reply #41 on: January 22, 2017, 07:47:21 pm »
Hi guys ,thank you for all your comments  :-)) .
Brian  B
Spinner
« Reply #42 on: January 22, 2017, 10:16:06 pm »
Looks fantastic Brian.  :-)) :-))
If you're ever showing them off let me know I'd love to have a look.
Peter Fitness
« Reply #43 on: February 12, 2017, 10:10:15 pm »
I had the pleasure of seeing Brian's latest masterpiece, Meili-Lady, in action yesterday at our club lake in Ballina yesterday (Sunday). I have followed the build of this beautiful model on Mayhem, plus Brian kept me up to date with his progress via emails, and to see it in real life was great. It performs every bit as well as it looks, and that's saying something. It's quite a big model and has a real presence on the water. Wonderful job, Brian.
Peter.
« Reply #44 on: February 13, 2017, 10:55:48 pm »
Beautiful  8)
B.B
  • B.B
« Reply #45 on: August 26, 2018, 06:42:00 am »
Hi there, finally got the chance to tow some gear behind her, Old Shrimper (Bob) was cruising through ( caravaning) so we gave her a run in the North Arm at Ballina nice sandy bottom also tried out my Turnigy underwater camera , after view adjustments we then tried the next week with the "Charissa" , cheers....
Brian  B
missyd
« Reply #46 on: August 26, 2018, 04:14:50 pm »
Wonderful model and fantastic fotos!  :-))
Danielle
neverupright
« Reply #47 on: August 26, 2018, 08:33:33 pm »
that is a work of art
B.B
  • B.B
« Reply #48 on: August 27, 2018, 02:03:37 am »
Thanks guys glad you enjoyed them  :-) .
Brian  B
