Author Topic: Hobby's side trawler  (Read 2512 times)
kpnuts
« on: January 01, 2017, 05:00:14 pm »
Hi all it may be a while before I start this as I have a 1/8 corvette stingray coming and I'm entering it in a big scale gb so that will take priority.
Anyway I thought this looked like a great kit with loads of potential for improving it, so here are a few pics of what you get in the kit, it was a chrissy present from my bro (thanks again jim)
Re: Hobby's side trawler
« Reply #1 on: January 02, 2017, 11:08:56 am »
That looks fun with a challenge. Please let us know how you get on, along with the problems  (if any )  as you go.
I have a large collection of matchsticks and wondered about the gluing and the time it takes to dry with a grip.   :}
ken
gregk9
    • Chasewater Model Boat Club
« Reply #2 on: January 02, 2017, 12:08:44 pm »
I did try one of these some time ago, but found the paper used for the backing a bit on the thin side, so you could only apply a limited number of sticks before the glue started to soften the backing and it started to loose shape, so had to stop to allow to dry off before continuing. internals could do with more formers to hold shape me thinks.
Best wishes.
Steve. G.
kpnuts
« Reply #3 on: August 17, 2017, 08:19:15 pm »
Hi all, well where do I start, I knew this would be a challenge (never tried this type of kit before) well if I do another, and that's a big if, I will change somethings there are no tabs just gluing edge to edge with the cardboard also they've modelled it with a flat deck (As we all know they're not they're curved to allow the water to run off) I've adjusted that the cardboard is very soft and thin also there is a bend into the middle of the hull template in order to fit it in the box since I've glued the hull together the sides toward the stern have gone concave so will have to unglue those and make some formers for ti to keep it out, I would suggest to future builders you trace the parts out not thicker and stiffer cardboard and add some tabs to increase the strength and make gluing easier.
Anyway here is where I am now .
« Reply #4 on: August 17, 2017, 08:47:31 pm »
Cripes, you are making good progress already Ken! I am surprised the designer does not have the builder make frames from matchsticks.
kpnuts
« Reply #5 on: August 22, 2017, 08:25:18 pm »
Hi all here's the next update.
I figure I will matchstick all the sides then sand them all down smooth and paint it rusty white or black also I intend to make the masts and stuff out of other materials
