Author Topic: Spring clip - hardware identification  (Read 2254 times)
C-3PO
« on: January 06, 2017, 09:04:34 am »
Hello,
In the past I am sure I have used a "push on spring clip" type fixing to allow fixing to something like the shaft of a potentiometer/ rod etc.
It's a little bit like the "D" clip you might find in a knob that would fix onto a potentiometer.
All I can picture is a collar with a zigzag split that allows the "grip"
Can anybody suggest what these might be called rather than just a clip!
I have Googled for images of spring clips so far without success
Thank you for any help
C-3PO
bfgstew
  • Comfortably Numb
Re: Spring clip - hardware identification
« Reply #1 on: January 06, 2017, 09:08:27 am »
Like on old ladies shopping trolley wheels, used to be a cap that pushed onto the shaft to keep wheel on, once on you had to destroy it to get it off????
"Give me a ping Vasili. One ping only, please"
bfgstew
  • Comfortably Numb
« Reply #2 on: January 06, 2017, 09:12:51 am »
Just come to me.......star lock caps.
« Reply #3 on: January 06, 2017, 09:32:27 am »
 :-))star lock washer
« Reply #4 on: January 06, 2017, 09:53:44 am »
Try maplin as i am sure i saw some of these in small boxes at my local one last weekend ...should be natuonwaide or even halfords
C-3PO
« Reply #5 on: January 06, 2017, 10:00:48 am »
Thanks guys - I will try Halfords
C-3PO
imsinking
« Reply #6 on: January 06, 2017, 10:17:52 am »
Spire nut too I think . . .
Bill
« Reply #7 on: January 06, 2017, 10:37:35 am »
Leaky Bottom
« Reply #8 on: January 06, 2017, 01:41:59 pm »
« Reply #9 on: January 06, 2017, 01:47:56 pm »
That's a great find - thank you for sharing - added to favourites for future reference. :-)
« Reply #10 on: January 07, 2017, 12:47:28 am »
Have just installed 36 x e-clips as one sided retainers for each individual the paddle blade shaft
The shafts are Imperial as 1/8" [0.125"] drawn brass bar.....for the individual [18 in total] paddle blade shafts
So I ordered 40 x N1500 Series Code 0012 in KSF material......[being non-magnetic & non rusting].....I was hoping for a Bronze material, however they turned out to be a Grade 300 series stainless material ........the nominated e-clip grooves were .023" wide x .018" deep
There is one at each inner end of the shafts, so the first one is relatively easy to install, the second on each shaft as it is hard up against a plate......
I should have ordered 50......as 2 snapped when being installed & 2 sprang into the air....never to be seen again  {-)
With the groove dimensions being correct, I suspect questionable heat treatment of the stainless sheet that these were stamped from, as the root cause of the e-clips failure
RAAArtyGunner
« Reply #11 on: January 07, 2017, 04:04:19 am »
C'mon Derek,
It's OK to underestimate one's own strength. %) %)
