Pages: [1] 2 3 4   Go Down
Author Topic: Hellers 1/8 traction avant cabriolet conversion  (Read 14978 times)
kpnuts
« on: January 06, 2017, 11:58:38 am »
Hi all well ive made a start on this mamoth project, unfortunately no pics yet as no internet or phone, and it sounds like we wont be getting it back any time soon, i will post pics as soon as we can borrow someones internet.
This is going to be the polar opposite of my last build and will be blinged up to the max, the engine will be pristine and shiny with some mild suping up (thanks to roy fitzimonds lovely 1/8 twin choke webber carbs) i was going to use all three but can't figure out how to realistically modify the manifold so will just be using one of them, i also have a set of his dunlop racing wheels for it. The body will also be ultra shiney, still unsure whether to sort of hot rod it and leave the front wings off or not, will have to give that some serious thought. In tandem with this im also building monograms 1/8 65 corvette stingray, i may do opening doors like roys or not, not sure if i want all the extra work. Anyways i hope to post some pics soon.
Re: Hellers 1/8 traction avant cabriolet conversion
« Reply #1 on: January 06, 2017, 08:44:40 pm »
Good show Ken. I look forward to seeing the work progress. regards Hotrods, we know you can do some splendid motifs such as those dragons and landscapes.
kpnuts
« Reply #2 on: January 06, 2017, 10:02:22 pm »
Sorry mate no dragons (pretty crap at that sort of stuff) but it will have a trick paint job.
kpnuts
« Reply #3 on: January 07, 2017, 03:22:43 pm »
Hi all a few pics of this monster kit.
This engine is almost as big as the monster in the stingray
« Reply #4 on: January 07, 2017, 04:53:51 pm »
It has a bloomin big block though  :-)) You can see the development from monoliths to more compact design ideas for engines. Imagine if the Stingray engine was an inline!
kpnuts
« Reply #5 on: January 11, 2017, 07:32:41 pm »
Woo hoo we have our Internet and phone back (only been off since the 23rd of december)
Here are some update pics
« Reply #6 on: January 11, 2017, 09:43:39 pm »
I remember your last engine being nice and busy looking. Keep up the good work.
mrzippy
« Reply #7 on: January 12, 2017, 09:58:49 am »
Another fascinating build to watch KP, great stuff !
My ears pricked up when you mentioned Webers and Dunlop racing wheels,
wondering where we find roy fitzimonds ? does he have a website etc ??
tried a quick Google with no luck to date.
many thanks Paul
kpnuts
« Reply #8 on: January 12, 2017, 10:18:06 am »
Check on ebay, he has a few things on there .
kpnuts
« Reply #9 on: January 15, 2017, 07:55:49 pm »
Hi all well I've glued some of the body together as I need to figure out what portion of and how I'm going to cut the roof off (that's a 1/24 mustang on the roof just to show how big this thing is)
« Reply #10 on: January 15, 2017, 09:09:25 pm »
It's a bloomin monster!
kpnuts
« Reply #11 on: January 17, 2017, 08:45:09 pm »
Hi all here is another update the engine cradle is sprayed what the main body colour will be.
Added the rear wings to the body
« Reply #12 on: January 17, 2017, 10:25:21 pm »
It is a nicely fine kit. It helps with being in a large scale making the parts thinner in proportion to their size.
kpnuts
« Reply #13 on: January 18, 2017, 08:09:10 pm »
Hi all here is the next update.
kpnuts
« Reply #14 on: January 19, 2017, 08:34:41 pm »
Hi all here is the next update, put the beading round the rear wheel arches, couldn't then resist seeing what the colour would look like so gave it a quick coat.
I have to say I think my other build was more interesting to look at, the weathering and oil staining give something more to look at, I think I will post some of the similar build pics together as this progresses to show what I mean.
kpnuts
« Reply #15 on: January 21, 2017, 06:29:59 pm »
Hi all I remember on the last build putting the driveshafts in at the allocated time was a real pain so I decided to do them now (I'm hoping that choice doesn't bite me in the tender area later.
kpnuts
« Reply #16 on: January 22, 2017, 08:06:33 pm »
Hi all, well I've done it, the roofs gone (hope I can make the canvas roof for it.
I'm going to use the cut out roof as a template for making the ribs for the canvas part.
« Reply #17 on: January 22, 2017, 10:38:19 pm »
That is a good idea regards using the roof piece. as a jig. She's coming along well. I am impressed with the drive train both on a historical level and how you have made it. Ok, so it isn't as filfy as your first one, but the detail and the fact you are adding the cables makes it impressive in other ways Ken. Are you going to use cloth or paper for the canopy?
kpnuts
« Reply #18 on: January 25, 2017, 08:37:12 pm »
Hi all here is the framework for the canvas roof (the nuts and bolts won't stay the final version will have a plastic pin) I may try a version using piano wire as the copper wire is very soft, it may stiffen up a bit when the canvas is stitched to it (that I think is going to be a nightmare, not known for my sewing skills)
Need to make a couple of of ribs for the middle section.
« Reply #19 on: January 25, 2017, 10:36:36 pm »
Copper can be 'pre stressed' by sticking one end of the wire in a vice and pulling the other end with pliers. You will feel it give a bit as you tug and this is the wire being work hardened. The wire will now be straight, less prone to bending though slightly harder to bend and you will have fewer chances to rebend it before it snaps. Do not pull too hard or you will break the wire.
The framework looks brilliant, and as usual, it looks very realisitc.
kpnuts
« Reply #20 on: January 26, 2017, 08:15:41 pm »
Hi all here is another update on this.
From my experience of building this kit before it is critical that this piece is glued totally square and true if you don't want bonnet fitting problems.
As you can see from the pics with a little effort you can get a perfect fit.
On my first build this part was out only by about a half a mill and when I fitted the bonnet there was a 5 mil gap at the top which I could not get rid of, after days of investigation scratching my head and swearing it turned out this was the problem, of course I had got a lot further on in the build and it caused me a lot of problems to sort it out.
kpnuts
« Reply #21 on: January 28, 2017, 07:32:52 pm »
Hi all another update, I've made the carpets out of wet and dry then the driving mat out of couser sand paper.
kpnuts
« Reply #22 on: January 29, 2017, 05:56:00 pm »
I think gold and purple are a great mix sooo,
Chrome
Some of this through the ab
And you end up with gold
« Reply #23 on: January 29, 2017, 07:43:57 pm »
The mat and carpet look great. I have used wet and dry for making roofing felt on various models but never though to use it for carpet.
What does the spring do on the piece you were making fit squarely?
kpnuts
« Reply #24 on: January 29, 2017, 08:04:32 pm »
It's the clutch return spring, nothing to do with the squareness  it's the bulk head that needs to be square on all faces.
Pages: [1] 2 3 4   Go Up
Page created in 0.14 seconds with 21 queries.
