Hi there, as far as I understand Derek was taking ratings from the 20 rpm
I wouldn't think it would be the same for the 200 rpm. The way I understand this at the moment is we are using the same motor but different gear ratios to give us the same speed; but, with changing gear ratios were are also changing the torque settings.
In all honesty we can look at the theory side of stuff and say in theory yes this should work; but in practice it doesn't. Therefore, its a case of 'suck it and see' as they say.
You will have to fit the 200 rpm motors into your model - try it in the tesk tank (the bath) and see. So, in theory it should work but to be on the safe side, best check.
john
