Author Topic: Wow, how many props?  (Read 2828 times)
Brian60
« on: January 16, 2017, 07:14:15 pm »
So what do you think this baby is that requires so much motive power, I think I can say nobody will get it....
Brian60
Re: Wow, how many props?
« Reply #1 on: January 16, 2017, 07:17:01 pm »
Because I'm going out and don't want to keep you all in suspense, here's the boat, called the Bucanero.  Its a fast crew boat servicing the rigs out in the Gulf....
TheLongBuild
  • Build em, and play hard..
« Reply #2 on: January 16, 2017, 07:22:21 pm »
Beat me to it  8) ........Not.
« Reply #3 on: January 16, 2017, 08:00:50 pm »
Nar nar nee nee nar we Geordies can go one better. Look how many props the Turbinia has.
hahahah  {-) {-) {-) {-) {-)
« Reply #4 on: January 17, 2017, 12:12:29 am »
The question is, 'Why so many props, what is the advantage?'
Is it speed, pulling power, or both?
« Reply #5 on: January 17, 2017, 02:55:27 am »
TT
....with the Turbinia, I understand the multiple propellers on multiple shafts was to load up the drive train in the attempt to overcome the immense cavitation that was created by the turbines high rotational speed & the as transferred high RPM of the propeller shafts
So here we would find that one propeller on each shaft on this vessel would each simply & uncontrollably cavitate  & go no where fast  O0
« Reply #6 on: January 17, 2017, 03:57:54 am »
Got it, thanks  :-))
furball
« Reply #7 on: January 17, 2017, 07:05:55 am »
Interesting... I've got a hull of what is probably a straight-runner that my father acquired in the 1930's that originally had twin shafts and two props per shaft (very much like the Turbinia), a fine pitch one on the end of the shaft, and a very coarse one further up. He thought it originally had a flash steam plant, so presumably had the multiple props for the same reason.
Lance
« Reply #8 on: January 17, 2017, 07:23:01 am »
Yes Lance......
Incorporating multi shaft - multi propeller drives were used in harnessing the massive output of flash steam powered model vessels [many were pre radio control]
Many of these were tethered around a pole.......still very dangerous  <*< if the cable failed .....
TheLongBuild
« Reply #9 on: January 17, 2017, 09:23:54 am »
Yes Lance......
No more dangerous than those running fast electrics untethered
TomHugill
« Reply #10 on: January 17, 2017, 12:39:00 pm »
Except the fast electrics are controlled and an uncontrolled tether boat isn't....
TheLongBuild
« Reply #11 on: January 17, 2017, 12:50:00 pm »
Debatable at times..
« Reply #12 on: January 17, 2017, 02:22:03 pm »
Hi there firstly - the link below is of Bob Kirtley's Pisces II - one of the fastest hydroplanes around - it did about 120 mph + - have a look at the thickness of the rope which secures the hydroplane to the centre pylon.   I would imagine the ratios of failures between the hydroplane breaking free and the high speed electric model running out of control, verges on the electric speed boat running out of control a lot more.  Also, Pisces has a single prop.
https://www.youtube.com/watch?v=ACqLSnaxrH0
Now to get back to the original topic - whilst I was at Newcastle Museum - looking at the Turbinia a few years ago - I recall there used to be side exhibits of trial models which Charles A Parsons built to experiment with various different props and prop shaft positions - to help with determining cavitation.  What made these models so interesting was they had a huge elastic band to drive the props and a huge starting handle to wind the elastic up.   I have been trying to find pictures of these on the web.
Page created in 0.096 seconds with 22 queries.
