Author Topic: vo 60 ocean racer decking  (Read 6826 times)
Eddie W
Re: vo 60 ocean racer decking
« Reply #25 on: February 16, 2017, 07:54:44 am »
As per link, using wax may be a possibility.
stringer
« Reply #26 on: February 17, 2017, 03:49:15 pm »
Well Martin
Yes it Does work using the black sealer, but I will have to find a finer nozzle though as the one supplied with the sealer even at its smallest produces an 1/8" diameter flow, I do have a small syringe which I use to fill the prop and rudder tubes on my schooner with grease but even that isn't small enough, also it's like s--t to a blanket it gets every where, but if I can find a syringe with a nozzle that is small enough I will be in business
Thanks for everyone's input and thanks again to you Martin .
Will put some pics on when I complete the deck
Before I do anything more I will dye the outer deck plank  around the edge of the boat, and the King plank to a dark colour and then the remainder can remain a honey colour, then seal ready for the infill
Geoff S
you will never fail as long as you try
