Author Topic: Wilton Castle paddle steamer sort of.  (Read 3008 times)
Waz
« on: February 01, 2017, 09:57:05 pm »
i am finishing off a paddle steamer built from the Wilton castle plans, the model has been extended and will be steam powered rather than electric powered as per the original plans. I will add some pictures shourtly.
Re: Wilton Castle paddle steamer sort of.
« Reply #1 on: February 02, 2017, 12:20:36 pm »
Look forward to that.  Welcome to Mayhem Waz.  We love pictures on here and don't see many paddlers.
Cheers,
ken
Waz
« Reply #2 on: February 03, 2017, 05:36:57 pm »
When I can work out how to upload pictures I will. It's my first attempt at boat building/finishing so I fear that some of the methods use may be a bit over the top however they work.
The engine had been mounted, steam reversing valve has been made, as two out of three servos fitted, just the boiler to be clad and mounted.
Waz
« Reply #3 on: February 05, 2017, 07:22:36 pm »
Well a bit of background on the boat,
The boat was purchased as part of a collection between myself and another member of my local model engineering club, from the lot I still have the paddle steamer which i am finishing off and also a 1/32 scale britannia Royal sailing yacht, which just needs sails making, the fate of which is undecided.
The paddle steamer is a widened and lengthened but based upon the wilton castle plans, however its got a home designed twin cylinder steam engine in the rear driving a set of metal paddle wheels.
I am fitting a tig welded gas fired boiler, along with a rudder mounted under the hull, and steam control valves. Once complete the boat will require 3 channels, One for steering, once for the direction control valve and the final one to control the steam throttle.
hammer
« Reply #4 on: February 06, 2017, 02:52:01 pm »
I am a fan of paddlers, having two, Glen Usk & Duke of Devonshire Both scale & steam driven(oscillators) . All to my own designs.
 I am glad to see you have plenty of draft, as that looks like a lot of weight aft. Balanced by the boiler mid ships, good.
Waz
« Reply #5 on: February 08, 2017, 04:20:19 pm »
Well today I thought I'd see how it sits in the water, and after raiding the workshop for metal to weigh it down it was off to the bath to float test, with the boiler full and everything fitted only the bottom 1/8" of the paddles were in the water so wight was added until happy with the weight. A total of 5.6kg was added. Now to order the lead shot and make the ballast weights.
KNO3
« Reply #6 on: April 09, 2017, 05:21:57 pm »
What are the big squarish bits of brass to the left and right of the crankshaft?
Waz
« Reply #7 on: April 12, 2017, 04:36:39 pm »
They are reduction gearboxes to reduce the speed down for the paddle wheels as there is no flywheels to aid slow running of the engine so the engine is run a bit faster and then the output speed reduced through the gear boxes
KNO3
« Reply #8 on: April 15, 2017, 05:32:02 pm »
Thanks. Could you please show a pic of the geaboxes inside?
« Reply #9 on: April 15, 2017, 07:55:17 pm »
Welcome to the forum Waz, that is a lovely piece of engineering that deserves a good boiler so she should run great  :-))
