Author Topic: Graupner 900 motors some help needed volts/Rpm  (Read 2056 times)
16-21
« on: February 12, 2017, 06:59:34 pm »
Hi all,
I was having a tidy out and found two graupner 900 Torque motors
Still boxed and not used.
I know the rpm at 12v is 6500
However would anyone now how the rpm will increase per volt added?
Say 18V =
And of course 24V
Many thanks
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
Re: Graupner 900 motors some help needed volts/Rpm
« Reply #1 on: February 12, 2017, 07:10:08 pm »
Don't use the Graupner 900 above 12volt.
Look at the stall current.
16-21
« Reply #2 on: February 12, 2017, 07:41:25 pm »
54amps stall current.
Range 6V - 40V
Nominal 12V
It's quite good idle current wise though.
Mike, when will you be releasing a new 40amp Esc??
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #3 on: February 12, 2017, 08:15:52 pm »
   At 12volt there was already enough energy in this motor to pop a bait boat supplier's well known brand escs. It was ok with my esc though. :-)   I suggest you connect wires to one of the 900 motors and to 12v and 24v battery. Where you make the connection it will have a tendency to weld together and erode contacts.
The idle current is only another numerical indicator of an efficiency peaking at less than 20% of stall current, as is the peak of 71%. A higher or lower idle figure loses significance if you load the motor down below 70% of no load rpm. If you don't use its high torque capability you may as well sell the pair to get four 800 equivalents.
16-21
« Reply #4 on: February 12, 2017, 09:13:28 pm »
I've sent you a pm Mike
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #5 on: February 12, 2017, 09:47:32 pm »
I say share your results and put the questions on the forum.
Page created in 0.09 seconds with 22 queries.
