Hi ya gingyer
The mould for the USS South Dakota is it a 3-way Split Mould? As I noticed, as well as protrusions, such as the bilge keel and the prop-shafts there are also recesses along the deck edge - just out of curiosity that's all - as the mouldings themselves, going by the photographs, look like they have been moulded by professional laminators. I cant see any evidence of any resin rich areas on the bottom of the mouldings in the areas of the bilge keels.
The only thing that does concern me - is - if you have a good team of laminators, who are building their experiences up - try to avoid moulding on items such as the bilge keels to the moulds, due to 2 facts - one that has already been explained i.e. pure resin has the habit of chipping and breaking off easily - the other one is that polyester resins tend to shrink a lot, when they have no glass structure behind them to support. So, you may find (if the bilge keels are pure resin) you may get distortion there over a period of time.
Long time ago when working in the moulding industry, we used to spray, using a fibre glass chopped spray gun and this gun was fed by roll material - that is chopped up by the machine and sprayed on to mould. One of the cheats we used to do, if we had a tight area such as you have in the bilge keel would be to (after the gel coat had set) put a small layer of tissue in - gently stippled into the area; then roll some of this chopped strand up from the machine into a string and lay that into the area - then wet out with resin. I have had a look at the website for fibre glass based here in South Shields and they now supply a string which might help you out. I noticed that the price of the roll for the machine is a bit on the pricey side, compared to the string. Somehow, though, looking at these mouldings; I am trying to teach me granny how to suck eggs here
https://www.ecfibreglasssupplies.co.uk/category/cloth-fabric-and-tapesJohn
