Hi Spud,
It looks like you are doing a good job on your build.
I have one of these kits, you have spurred me on to make some progress with it.
As this will be my first build i have spent a lot of time reading up and searching for build logs on the tinterweb.
May i ask what glue you are using? Have you any thoughts on sealing, varnish, paint, prop/propshaft, motor and electrics?
I have decided to install a brushless outrunner so i will need to modify the motor mounting position and i am upgrading the propshaft to 4mm with a brass prop.
I also intend to have working lights controlled by an RC relay.
I am trying to do as much of the mods as possible before i put the side pieces on to allow more room for my fingers and a better view.
Good luck with your build and please can we have lots more photos.
