March 29, 2024, 02:18:40 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
Scewed 6 Blade Props
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Scewed 6 Blade Props (Read 1531 times)
SANDALL
Shipmate
Offline
on:
March 02, 2017, 03:18:28 pm »
I have a pair of 60mm 6 Blade Scewed Props will they be o.k on my 1/96 Scale Arleigh Burke ? .
Full Mayhemer
Offline
Huntingdon, Cambs, England
Huntingdon, England
Re: Scewed 6 Blade Props
Reply #1 on:
March 02, 2017, 05:41:10 pm »
I would have thought they were rather large, scale 5.7 metres. Will you be able to get the required clearance from the hull with the shafts at the correct angle?
SANDALL
Shipmate
Offline
Reply #2 on:
March 02, 2017, 08:03:17 pm »
Hi
The Shafts already fitted ,& had a pair of 5 blade 60mm Props attached O.K .but through my neglect threw one whilst sailing /.
Just wandered if the 6 blade scewed are adequate for propulsion . Clearance NO PROBLEM .
Full Mayhemer
Offline
Wollongong Australia
Reply #3 on:
March 02, 2017, 10:57:37 pm »
I had the pleasure of a guided tour of a DDG51 Class Destroyer in 1986, but the propeller size was not discussed
.....however Google can help...
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0ahUKEwiolpbl77jSAhUHppQKHdUUAgoQFgg7MAc&url=http%3A%2F%2Fwww.dtic.mil%2Fcgi-bin%2FGetTRDoc%3FAD%3DADA582048&usg=AFQjCNFQrV7NE_rSczaDk04Nr1jtfB01gg&bvm=bv.148747831,d.dGo
This [
slow loading but well worth reading
] official article contains the final recommendations for the on the hydrodynamic build considerations for the DDG51 Bourke Class destroyers
Page 18 in the recommendations nominates that although 18 foot diameter propellers will cost more than 17 foot diameter propellers, fuel savings over time confirm the 18 foot CPP's will be more cost effective
So there is your answer 18 foot = 5486 mm divided by 96 = ~~57 mm
Does this surprise you?
Now the question of blade numbers?........the Class certainly had five blades
....not six
The other consideration...with all things being equal, a 6 blade propeller to identical design of a 5 blade propeller of equal diameters will draw ~~20% more power
Geoff
Full Mayhemer
Offline
Reply #4 on:
March 03, 2017, 01:17:20 pm »
A bit unrelated but if the 6 blade draws 20% more power will it also give 20% more thrust so the revs can be lower so power consumption reduced!
Geoff
Full Mayhemer
Offline
SW Surrey, UK
Reply #5 on:
March 03, 2017, 01:27:03 pm »
It will put a greater load on the motor which will reduce the revs but power consumption will almost certainly rise. Whether the model will actually go faster on the same voltage is a bit 'suck it and see'.
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
