Technical, Techniques, Hints, and Tips > Wood Care:
Iron on banding
flyte:
Hi everyone, straight to the point, has anyone considered using "iron on" edging/banding to simulate planking ? I've used it many times in the past for small projects with great results. My local DIY shop keeps a good supply at very good prices (around £3 to cover the deck of a 2' boat) It's real wood in just about any species you can think of, it's 0.6mm thick and comes in 3 sizes, 22mm-50mm. Its very simple to use, just lay it on and iron it and it will take any stain varnish or other finish.
Obviously it would have to be laid over existing or new wood as it has no strength, but the effect is excellent. I tried it today with some scrap pieces I had, cut into 10mm strips and glued onto plywood. I used beech and marked the edges to simulate caulking, it really does look the business ! Also, it bends and shapes and cuts very easy.
So what do you think guys ? has anyone tried it ? can you see any problems ?
Netleyned:
Can you be sure the glue is waterproof?
flyte:
Hmmmmm, I'm not sure, though I made a router table and edged it once, the table has stood in a damp outside shed for years and still looks fine. I was thinking that once its in place and treated/sealed/varnished it would be ok.Do you think it would cause problems even after being treated ?
I did find similar edging that needs to be glued so maybe that's a better bet.
I know it sounds like a bit of a cheat to do this but I'm really impressed with how it looks, the finish is nice and smooth, no sanding needed, and the range of wood types is extensive.
unbuiltnautilus:
I don't think the adhesive is a fully waterproof one, but then neither is PVA and people build models with that. It is all down to the protection you apply to the exposed edges and the timber itself. I think if it is suitably coated with thinned, then pure varnish, two to four coats deep, it should be fine....let us know if it all falls off though :}
flyte:
If it all falls off you will be first to know {-)
Just been reading and the glue used is the "hot melt" type, I suppose that's why you melt it with an iron !!!! damn.....I can be dumb at times ! anyhow, it's pretty much waterproof and when you think about it they use it on kitchen worktops which constantly get wet. But like unbuiltnautilus said, the important thing is how you protect it, if you used waterproof glue on your hull then coated it with peanut butter it might taste ok but it wouldn't stay afloat for long.
Navigation
[0] Message Index
[#] Next page
Go to full version
