Model Boat Mayhem - Forum
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... 42   Go Down
Author Topic: MMM Portgarth build  (Read 120703 times)
chipchase
Re: MMM Portgarth build
« Reply #200 on: April 07, 2017, 11:02:56 PM »
I think the Portgarth would be at the bottom if she tried that Andy LOL
T33cno
« Reply #201 on: April 07, 2017, 11:03:53 PM »
Only if the hatches leak  {-)
derekwarner_decoy
« Reply #202 on: April 08, 2017, 05:10:49 AM »
I don't quite understand what the tug skipper is trying to achieve %)
1. my knowledge of tug handling is near ZERO
2. his tow line is about 130 degrees AFT & to the port
3. the tug thrust appears a FWD with a slight vessel beam turn to PORT??
T33cno
« Reply #203 on: April 08, 2017, 06:47:29 AM »
Assuming they are working as a pair he is steering the rear
T33cno
« Reply #204 on: April 08, 2017, 08:16:44 AM »
That worked  :-))
T33cno
« Reply #205 on: April 08, 2017, 01:24:19 PM »
Almost a perfect day, very shortly turn satin  :-)
Paul2407
« Reply #206 on: April 08, 2017, 03:05:26 PM »
Looking great Andy  :-))
The more I see that hull the more I like it, it just looks the perfect tug  :-)
T33cno
« Reply #207 on: April 08, 2017, 03:07:55 PM »
Thanks a Paul and my apologies for the other post, thread was closed so I could not reply  :-X
Those prop shafts are huge  {-)
Paul2407
« Reply #208 on: April 08, 2017, 03:19:28 PM »
No need mate that's fine, a phone call to "anonymous"  :-X supplier and all sorted now anyway thank you :-))
T33cno
« Reply #209 on: April 08, 2017, 03:24:56 PM »
I'm trying to resist starting on her now  %%
I think in the long run it'll all get a fine wire wool rub when the top half is painted and re lacquer over the whole
Paul2407
« Reply #210 on: April 08, 2017, 03:42:27 PM »
Hmmmm not tried the fine wire wool trick, knowing me I'd strip the paint back off  {-)
T33cno
« Reply #211 on: April 08, 2017, 03:42:59 PM »
A good day for remodelling my stand from temporary to permanent
A bit of reinforcement , sanding sealer and a fine rub. Just waiting for the felt strip to arrive .
I'm going to make a guard for the rear so I can't knock the Korts off
Paul2407
« Reply #212 on: April 08, 2017, 03:52:43 PM »
You've made a nice job of that, you'll have to pop down and show me how to make a stand as that's a job I've been meaning to do but at a loss how to get the curve of the hull drawn onto the wood to cut out  {:-{
T33cno
« Reply #213 on: April 08, 2017, 04:01:07 PM »
Cardboard is free  :-)  practice making templates of the hull shape front and rear then transfer onto wood.
I'll go take a photo of the one I've knocked up for the Rotty  :-))
T33cno
« Reply #214 on: April 08, 2017, 04:03:48 PM »
Left over skirting board. Once you get something close to the shape you can fine tune it when the boats sat on it
I will eventually make a more ornate stand for presentation but this will do for sail days
Paul2407
« Reply #215 on: April 08, 2017, 04:38:59 PM »
Great that perfect gives me a good idea what it should be like, I'll have a go at something this week it's much needed as the stand I got with it is nothing more than 10mmx10mm wood made into a rectangle with some felt stuck to it
T33cno
« Reply #216 on: April 08, 2017, 05:03:23 PM »
Ready for business, be in the bath tomorrow evening  :-)
T33cno
« Reply #217 on: April 08, 2017, 06:56:34 PM »
Couldn't wait it's all going down  O0
chipchase
« Reply #218 on: April 08, 2017, 06:58:19 PM »
Looking good Andy, you will have her finished in a fortnight the way your building. LOL
T33cno
« Reply #219 on: April 08, 2017, 07:02:57 PM »
Looks that way aye but we know there's an awe full lot to do above deck
No rush really and I've holidays too getting in the way  {-)
Really the longer it takes the more bang for buck  :-))
T33cno
« Reply #220 on: April 08, 2017, 07:03:49 PM »
Could well be in the bath tonight though  O0
T33cno
« Reply #221 on: April 08, 2017, 07:08:31 PM »
Another of my inovative ideas. Yes paxolin again. Waste coins from drilling at work make great junction reinforcements combined with resin
T33cno
« Reply #222 on: April 08, 2017, 07:10:51 PM »
A major consideration with super smooth shafts is they can only be installed from inside! they are 8mm but drop to 5mm for the props (6mm is also an option)
T33cno
« Reply #223 on: April 08, 2017, 07:12:26 PM »
Steve @ model boat bits made the 8mm to 8mm couplings specially at no extra charge  :-))
Paul2407
« Reply #224 on: April 08, 2017, 07:15:03 PM »
That's excellent service from Steve :-))  Certainly a supplier I will be using more of in the future
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... 42   Go Up
