Model Boat Mayhem - Forum
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 42   Go Down
Author Topic: MMM Portgarth build  (Read 112080 times)
mersey dave
Re: MMM Portgarth build
« Reply #25 on: March 19, 2017, 12:03:37 PM »
Looking good  :-)) them motors look good ..... what type are they.
Regards Dave.
T33cno
« Reply #26 on: March 19, 2017, 12:07:40 PM »
Made by Valeo I believe to drive a chair lift through a gearbox.
The pair in my Athon only draw 10.5 amps on full load
mersey dave
« Reply #27 on: March 19, 2017, 12:13:26 PM »
Thanks mate  :-)) I do like the look of them.......will have to have a look on the web.
Regards Dave.
T33cno
« Reply #28 on: March 19, 2017, 01:44:46 PM »
Having satisfied myself that I've got the shallowest shaft angle possible, I've set the shaft supports in place with P38
The shaft ends are set as close to the Korts as possible with the Eze extensions removed.
I now have hands free for further fine adjustment. There is still play in the P bracket holes and not glued to the tubes at this point.
T33cno
« Reply #29 on: March 19, 2017, 01:52:47 PM »
Regards Dave.
These are the closest regular boat motor but small in comparison and mine have huge bearings and 8mm shaft
http://www.cornwallmodelboats.co.uk/acatalog/cem900.html
T33cno
« Reply #30 on: March 19, 2017, 02:10:50 PM »
At this early stage I'm already thinking this must have a huge displacement so I would think it ought to handle 2x12 volt 9ah ?
This should enable well over two hours play
mersey dave
« Reply #31 on: March 19, 2017, 03:02:20 PM »
The 900 motors are what I have in my maltby driving 65mm props runs very well with loads of power.
Regards Dave.
T33cno
« Reply #32 on: March 19, 2017, 03:09:27 PM »
Glad I made the stand which works equally well upside down. Many jobs would be so difficult without it.
Bowthruster marked, I've chosen a spot that allows the maximum length of tube
T33cno
« Reply #33 on: March 20, 2017, 08:29:05 PM »
My first ever cut & thrust. Now please tell me what is the best fixing method? should I go with the P38 or Resin?
Tug-Kenny
« Reply #34 on: March 20, 2017, 08:37:42 PM »
I would apply P38 to the outside to hold it in position and then resin the inside for strength.  When dry, you can smooth down the outside flush with the hull, knowing that it is held firmly  (and permanently) by the resin.
Hope this helps
ken
T33cno
« Reply #35 on: March 20, 2017, 08:39:02 PM »
Hope this helps
ken
Yes that makes very good sense! thank you Ken
Tug-Kenny
« Reply #36 on: March 20, 2017, 08:40:56 PM »
I'm often faced with the same type of problem.  P38 does tend to be brittle when out loose in the air and not supported very well.
glad to help
ken
T33cno
« Reply #37 on: March 20, 2017, 08:43:09 PM »
glad to help
ken
Very much appreciated  :-))
tugnut
« Reply #38 on: March 20, 2017, 08:59:49 PM »
That's looking very neat  :-))
T33cno
« Reply #39 on: March 20, 2017, 09:02:05 PM »
Thanks yes I'm quite chuffed  :-)
I drilled a couple of 25mm holes close together each side with a thin wall hole saw and then purely half round file. Took about half hour
Thruster is 28mm OD
T33cno
« Reply #40 on: March 20, 2017, 09:45:25 PM »
Notes of the day
1 :- Steve @ modelboatbits is altering two powerflex couplings for me to give 8mm to 8mm plain. Not a stock item.
2 :- I've emailed MMM about the Kort tube supports and asked for a replacement for the rubbish one.
No reply yet
  • North wales
« Reply #41 on: March 21, 2017, 03:05:11 AM »
P38 has no strength in it st all...use P40 to fix the shafts in place or even epoxy glue
No Motor is to Big for me.....Catch it if you can Phil
T33cno
« Reply #42 on: March 21, 2017, 06:58:31 AM »
Cheers Dave :-))
T33cno
« Reply #43 on: March 21, 2017, 12:45:05 PM »
It has occurred to me that as I've made such a good job of my thruster holes that this would be a good time to transfer them into a template for future builds or sharing
T33cno
« Reply #44 on: March 22, 2017, 06:33:50 PM »
Today at work I explored the possibilities for something to align the Kort tunnels and I came across some stock copper pipe end caps that fit like a glove  :-)) .
Props are on order with Simon at Protean and should be with me soon UNLIKE the SIX WEEK nonsense of prop shop  >>:-(
A replacement Kort support is on its way from MMM but did not arrive today.
EDIT
These end caps are a no.67 that I believe relates to the O.D. of the pipe 67mm so the outside diameter is bang on 70mm
Friday is SMELLY day. I don't work Friday so anything that gets up the wifes nose must be done then!
Isopon etc is taboo  <*<
T33cno
« Reply #45 on: March 22, 2017, 08:48:14 PM »
This is my demountable platform for all the Action electronics. Paxolin glues very quickly with the product pictured. I've also made the stern tube support bulkhead of the same.
T33cno
« Reply #46 on: March 22, 2017, 08:52:19 PM »
Looking good but unfortunately this Kort is full of pin holes and requires time and expense that should not really  be needed.
The colour is Halfords filler primer and its going to need a good bit more
T33cno
« Reply #47 on: March 22, 2017, 10:50:02 PM »
I'm absolutely impressed with this Zap A Gap glue
T33cno
« Reply #48 on: March 24, 2017, 11:58:47 AM »
So props and bow thruster glassed in (thanks to those who gave advice) :-))
Ready for filler
All abraded
secured externally and ready for triming later
T33cno
« Reply #49 on: March 24, 2017, 12:02:35 PM »
Sikaflex 221 PU adhesive filler has just arrived so I'm going to set my motors & mounts in place next.
Props arrived yesterday from Protean  :-))
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... 42   Go Up
