Author Topic: Temporary pools  (Read 4926 times)
Paul2407
Re: Temporary pools
« Reply #25 on: April 09, 2017, 10:05:00 am »
Have to say I miss my Passat B5.5  :(( great car that was until someone wrote it off outside my house NOT once but Twice  <*< the first time I repaired it but the second time it was too bad
JayDee
    • JOHN DOWD
Re: Temporary pools
« Reply #26 on: April 09, 2017, 10:23:45 am »
Hello,
The pool at Coalville was really well engineered, solid construction - - NO LEAKS at all !!.
All of the parts were of similar size, it would be easy to transport.
Drainage points were built in, allowing slow release of water when draining, if required.
Quite the best pool I have seen !!.
John.  :-))
http://www.john-dowd.
Re: Temporary pools
« Reply #27 on: April 09, 2017, 01:42:48 pm »
So an all up weight of around 19 tonnes for the 16x24 ft pool.
The figure soon mounts up.
Re: Temporary pools
« Reply #28 on: April 09, 2017, 08:11:36 pm »
Ha ha thats mine......water didnt even go near it when i emptied it.....think the hosepipe in the Norbreck will be running for a wee while eh Malcs....
..Indeed it will - that's why we like to get started as soon as we can on the Friday with a full 24X24.  If only they had a bigger hose that we could use.
I do hope that the OP took note of the side bowing problem with the straw bale arrangement.  Deeper water exerts a lot more sideways pressure, and by the time it gets noticed, it's a bit late.
canalpilot
Re: Temporary pools
« Reply #29 on: April 14, 2017, 02:50:40 pm »
Up-date from Canal Pilot.  The liner has arrived and the hay bales come on Sunday, the next thing is to build the pool!!!
We have been told that a friendly word with the local Fire Service might help.  There should be hydrants on site as it is an old airfield.
TheLongBuild
  • Build em, and play hard..
Re: Temporary pools
« Reply #30 on: April 14, 2017, 04:26:39 pm »
Have I missed something, what's all this for ?.
imsinking
Re: Temporary pools
« Reply #31 on: April 14, 2017, 07:19:37 pm »
Ellsmere port M B C are building a pool in a top secret location , eye's only I'm afraid . . .
Bill
kinmel
Re: Temporary pools
« Reply #32 on: April 14, 2017, 07:34:36 pm »
Bill
Got to be at Hooton Park then.        http://www.hootonparktrust.co.uk/
 Ask  vauxhall works brigade to fill it for you.
canalpilot
Re: Temporary pools
« Reply #33 on: April 17, 2017, 02:18:41 pm »
The pool is now buily, all we need now is water!!
canalpilot
Re: Temporary pools
« Reply #34 on: April 17, 2017, 02:19:11 pm »
I mean built!!
imsinking
Re: Temporary pools
« Reply #35 on: April 17, 2017, 02:36:21 pm »
That's a relief , at first I thought you said B**GERED  %%  it's the way my mind works !
Yes water will be important . . .
Bill
Page created in 0.085 seconds with 21 queries.
