April 18, 2024, 07:05:26 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 25, 26
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
Propeller shaft
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Propeller shaft (Read 1294 times)
merseyferry
Full Mayhemer
Offline
liverpool
Propeller shaft
on:
March 24, 2017, 08:19:28 am »
hi again all ,why does the propeller keep tightening when the motor turns.. the set up ive got is from propeller end ... propeller lock nut, washer, shaft ,,, other end . washer, locknut coupling motor.
Administrator
Full Mayhemer
Offline
Peterborough, UK
Re: propeller shaft
Reply #1 on:
March 24, 2017, 08:32:00 am »
I would suggest a little 'nail polish' on the threaded areas to lock them in place.
( Loctite or superglue may be too strong in this application )
Giant Models
imsinking
Full Mayhemer
Offline
Merseyside
Re: propeller shaft
Reply #2 on:
March 24, 2017, 09:36:17 am »
You have to lock the nut against the prop tightly, finger tight wont do , same the other end lock the nut against the coupling . . .making sure there's no excess end float , the bigger the gap the more water gets into the stern tube, a big problem if your shaft set up is below the water line completely
I've used M3 stainless grub screws for years in both the props & drive end , plastic props not easy, all brass is totally safe . . .tend to strip the threads to easily in the plastic props , so don't over tighten . . .
Isn't model boating FUN
Bill
Full Mayhemer
Offline
Blackpool, Lancs, UK
Re: Propeller shaft
Reply #3 on:
March 24, 2017, 05:42:17 pm »
The common mistake is to hold the shaft and wind the locknut against the prop or coupling, which gives the appearance of a locknut, but isn't locked. Hold the prop to tighten its nut, hold the coupler to tighten that one. As suggested, adding a drop of thread locking compound helps.
merseyferry
Full Mayhemer
Offline
liverpool
Re: Propeller shaft
Reply #4 on:
March 24, 2017, 06:28:25 pm »
thank you gents.. still amasses
me how helpful mayhem members are
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
Propeller shaft
