Pages: 1 [2] 3 4   Go Down
Author Topic: Al Khubar build  (Read 20306 times)
Del Boy
  • Model Boat Mayhem really helps me out!
Re: Al Khubar build
« Reply #25 on: October 22, 2017, 05:30:16 pm »
Hi Andy, yes they both turn quite freely so I am a bit confused. I will have a go at swapping over the UJ's tomorrow and then the motor, I guess something could be out of line but just to check before hacking into the joints!
T33cno
Re: Al Khubar build
« Reply #26 on: October 22, 2017, 08:23:23 pm »
Good approach  :-))
Are your shafts lubed?
These are better if you are aligned.
http://www.modelboatbits.com/MICROFLEX-COUPLINGS
I use these but specially modified by Steve to 8mmx8mm plain
http://www.modelboatbits.com/POWERFLEX-COUPLINGS
Del Boy
Re: Al Khubar build
« Reply #27 on: October 25, 2017, 08:57:06 pm »
Hi T33cno, thanks for this, you will see why in a moment! First I tried to see if the motor was running true, seemed to be. Next I swapped the Pt prop shaft for the Stb one, no real difference I could see. I desperation had a rummage in my VERY old spares box (circa 40 years at least) and found an old spare plastic UJ. Fiddled around with this and got it on the shaft and it has made a significant difference. Too embarrassed to run with this so will be buying a pair of Microflex tomorrow! I see they have an oiling system so might buy that as well funds allowing. Daft question I know but what stops the water running up the tube and into the bilge? In my youth the shaft was filled with grease but MS say don't do that as it creates drag, any thoughts on that? Thanks again for the tip on couplings, much appreciated! :-))
T33cno
Re: Al Khubar build
« Reply #28 on: October 25, 2017, 09:06:12 pm »
Thick oil like 20/50 is most popular me thinks and recommended by MMM too. Without an oiling tube there is little option but to use a waterproof grease in my mind but others may know better.
As for water penetration the oil not only lubricates but is a barrier.
I oil my tubes or top them up prior to every outing.
Del Boy
Re: Al Khubar build
« Reply #29 on: November 18, 2017, 01:11:04 pm »
Ok so after a bit of a break that included a trip to the IMBS in Warwick (that I found inspirational and made me realise I need to try a lot harder!) got out to the workshop. I have started to fix the deck supports
https://www.flickr.com/photos/155484366@N08/37718507814/in/album-72157687411062660/
Then my pal Longshanks who was up for the IMBS helped me mark up the water line
https://www.flickr.com/photos/155484366@N08/37718497924/in/album-72157687411062660/
https://www.flickr.com/photos/155484366@N08/37718492914/in/album-72157687411062660/
We then ran a test to see how much ballast will be needed......
https://www.flickr.com/photos/155484366@N08/38377226586/in/album-72157687411062660/ supposed to be a tug but note the cargo capabilities!
https://www.flickr.com/photos/155484366@N08/37718526824/in/album-72157687411062660/ sits very nicely.
Weighed all this lot up and then the white metal fittings, estimated the remaining plastic and finally Rx, Servo, ESC's etc. and should be roughly OK.
Need to fix a battery 'shelf' and the rest of the deck supports next.
Del Boy
Re: Al Khubar build
« Reply #30 on: November 19, 2017, 08:44:12 pm »
Battery support installed and sealed in with P38. Boring I know but all I had time for today!
P1000632 by DEREK RULE, on Flickr
Support beams next.
longshanks
Re: Al Khubar build
« Reply #31 on: November 19, 2017, 10:52:01 pm »
Longest journey starts with the first sixth step  ;)
Del Boy
Re: Al Khubar build
« Reply #32 on: November 21, 2017, 09:00:17 pm »
Started on the foredeck supports now. Bit tedious but OK. Need more clamps!
P1000636 by DEREK RULE, on Flickr
Whilst they were drying tried a simple Rx layout design....
P1000634 by DEREK RULE, on Flickr
Interesting, what I thought was going to be lots of space ends up quite small!
Del Boy
Re: Al Khubar build
« Reply #33 on: November 23, 2017, 08:52:22 am »
Made a start on the battery mount yesterday. Used 15mm sq. pine and seems to do the job. Longshanks recommended not fitting the end stop yet so that come balancing time I can move the battery forward if needed, clearly a great idea. That should be relatively easy to add later as there is a big opening under the bridge once deck etc. is all in place and final trimming is needed.
P1000637 by DEREK RULE, on Flickr
P1000638 by DEREK RULE, on Flickr
Hoping to find time for deck fitting today.
longshanks
Re: Al Khubar build
« Reply #34 on: November 23, 2017, 02:19:27 pm »
That's not going anywhere  :-)
Don't know what the jury think (I've never worked with big lead acid cells).
Is it worth putting a strap of some sort over the top??
Kev
T33cno
Re: Al Khubar build
« Reply #35 on: November 23, 2017, 07:40:40 pm »
No straps on mine, they're far too heavy to move on their own. :-))
Del Boy
Re: Al Khubar build
« Reply #36 on: November 23, 2017, 09:45:05 pm »
Thanks for the suggestion Kev, it does feel very secure (famous last words) plus of course 'er indoors is good at that sort of stuff so will be requested depending on 'er mood!
Thanks too Andy I will see on the first few sails how it goes, it does seem to weigh a ton so should be stable like yours.
Must admit a Grumpy Monk tonight  :(( , just could not get an acceptable fit around the decks .... must try harder
P1000640 by DEREK RULE, on Flickr
So to cheer myself up I started mounting the various bits of electronic gear on the plate I intend to use, that went better!
P1000641 by DEREK RULE, on Flickr
Will continue with this over the w/e
Thanks for checking in chaps, much appreciated!
david48
Re: Al Khubar build
« Reply #37 on: November 24, 2017, 09:14:06 am »
I have had thoughts about battery movement in my Fairmount , its is not the movement when its on the water ,its when its in the car . Because thy are very difficult to get in and out thy have to stop in all the time so when the car hits a hole the battery there is a slim chance because thy are heavy it could do damage ,that's why I secured them down.
That's my twopennys worth .
David
T33cno
Re: Al Khubar build
« Reply #38 on: November 24, 2017, 09:29:27 am »
I find it best to transport the batteries separately and fit them when at the pond. This makes everything lighter and easier to handle.
Fair point about difficult access David. Mine is made easier by using two rather than one huge one
Del Boy
Re: Al Khubar build
« Reply #39 on: December 05, 2017, 08:32:52 pm »
David, Andy, first of all thanks for the suggestions, hints and tips. In fact I do have to own up, the battery I have been showing is from my dingy inflator so 'free' to a certain extent. I thought I would try with that first, see how I got on and then if a change of strategy is needed buy two smaller cells just like yours Andy. Just me being cautious really but I do like the idea of fitting at the lake, will give some thought to transport needs and supporting it up high to do this fitting. Back in the workshop briefly today and threw in (quite literally and I know it looks it as well) two supporting beams for the Rx shelf. Not pretty but hopefully functional. I am hoping to tackle the final fit of the rudder servo tomorrow. Bit worried as part of that linkage has to go under the rear deck and don't know if my fingers and thumbs can manage that but that's to think about tomorrow.
P1000642 by DEREK RULE, on Flickr
david48
Re: Al Khubar build
« Reply #40 on: December 05, 2017, 08:47:01 pm »
Make your self a dummy battery out of wood the same size as the battery you intend to use ,then its not heavy to use and you can build round the space it takes up ,then you know you can get it in and out.
David
ChrisF
  • What's my favourite cake!
Re: Al Khubar build
« Reply #41 on: December 05, 2017, 09:35:35 pm »
You're making a nice neat job of everything, good work.
Building Fairey Marine boats: River Cruiser 23 prototype, Huntress 23 Long Cabin with stern-drive, Huntsman 28, Huntsman 31 and Swordsman 33 and two more to come! All scratch built and to a scale of 1:12
Del Boy
Re: Al Khubar build
« Reply #42 on: December 06, 2017, 09:15:31 pm »
Thank you Chris, the encouragement is well received!
Fixed the Rx and ESC shelf in place tonight, added a simple rudder linkage too to see what issues I might get.
P1000644 by DEREK RULE, on Flickr
Then dropped the rear deck over just to see if I had the right access etc. to remove and lift out for adjustment and repair, dare I say it but seemed OK!
P1000646 by DEREK RULE, on Flickr
Thanks for stopping by....
T33cno
Re: Al Khubar build
« Reply #43 on: December 06, 2017, 09:29:54 pm »
There's tidy for you  :-))
ChrisF
Re: Al Khubar build
« Reply #44 on: December 06, 2017, 09:40:07 pm »
Derek, interesting that you have  the rudder servo on its side to suit the low rudder assemblies, not seen that before.
I'm about to start building a boat that would benefit from a reduced height rudder but was concerned that water could get into the hull up the shaft. Can this be a problem?
Chris
longshanks
Re: Al Khubar build
« Reply #45 on: December 06, 2017, 10:54:37 pm »
Wow that's neat, love it
Del Boy
Re: Al Khubar build
« Reply #46 on: January 03, 2018, 08:02:16 pm »
So, December, Christmas and New Year out of the way and back in the Workshop at last!
First thanks for the kind comments chaps, much appreciated.
Chris, I have no idea if water comes up the rudder tubes (bet it does!) so will no doubt need to solve that one!
David, appreciate the battery size comment. At the moment the battery is 'stolen' from my Dingy Inflator box and if it works in the tug on the water I will be happy. If not and weight distribution etc. becomes a problem I will go and buy two new smaller batteries as T33CNO did on his build.
In the meantime looking to site the Rx. I have read that this should go as high as possible and one aerial horizontal and the other vertical. Methinks best place for that then is in the superstructure somewhere. To do that I would need to extend the ESC / Servo cables but has anyone had interference problems doing this before, I suspect it needs about 300mm to be comfortable. Any thoughts please?
Ta
longshanks
Re: Al Khubar build
« Reply #47 on: January 06, 2018, 06:04:56 pm »
Happy New Year
Top of the rudder shaft should be above waterline, so no problem ....
Re RX In my experience as long as it's high in the hull I've had no problems
Kev
Del Boy
Re: Al Khubar build
« Reply #48 on: January 06, 2018, 07:50:48 pm »
Happy New Year to you Kev, trust it's warm enough for you! Thanks for the comments, rudder shafts do indeed look just above the waterline. See Rx later.
First shot, my Christmas present, very comfy, can recommend one to anybody with a bad back!
P1000668 by DEREK RULE, on Flickr
After much dithering and extending servo cables etc. to give some flexibility in mounting higher up the hull I made up a simple Rx Battery Box
P1000670 by DEREK RULE, on Flickr
Tucks in nicely twixt the two motors.
P1000671 by DEREK RULE, on Flickr
Bit of twiddling and fixing tomorrow then on with making it all a bit stronger.
Del Boy
Re: Al Khubar build
« Reply #49 on: January 16, 2018, 07:25:30 pm »
Made some progress today. Tidied up some of my wiring, dry ran the Tx, RX, Mixer, ESC's etc and then pulled it all out prior to painting. Just finished putting a supporting fillet under all the deck supports and will tackle the hatch supports tomorrow. Sorry the photo is not too clear!
P1000689 by DEREK RULE, on Flickr
More later!
Pages: 1 [2] 3 4   Go Up
