am building a 1:100 scale bulk carrier based on builders drawings. The hull will be some 180 cm long and approx 30 cm wide. The original is a geared vessel with grabs and so has 5 hatches.
Instead of having to load/unload lead weights I would like to fix something along the following lines.
The hull will contain one (or several) tanks that can be filled /emptied by means of water pumps controlled by the Rx. The tanks will have several internal walls to prevent the water ballast from slushing back and forth, causing instability.
Initial calculations indicate I would need to load some 45 -50 liters to get down to the waterline. It would be perfect to find a pump that has a capacity to fill the tanks in 5 -10 minutes. I guess I will need one pump for filling, one for discharging the tanks.
Has anyone tried this and what is your experience? As I have some 100 meters pretty rough terrain beween the parking lot and the edge of the water it wuold be nice to be able to get the model and radio down to the water in one trip.
Yr comments/suggestions most welcome.
Claes
