Am building a bulk carrier based on a Deans Marine Mouldings hull. I would like to get a complete drive line - motor, propeller shaft and propeller - that "work" together - motor axle should match propeller shaft etc etc.
Propeller should be diameter 70 mm, 5-bladed. Propeller shaft should be water lubricated, sealed and same diameter as the motor axle. Motor: high torque, low speed, 12 V. Speedcontroller to mtach . The modell is 175 cm long, 32 cm wide and torque is more important than speed so the motor should preferably do something like 3500 - 5000 rpm.
Have no ideas abt brushless motors or not - what I want is a motor that can be run for extended periods of time without burning...
Have been recomended to use a car fan motor but that will most probably mean the motor axle has to be modified to match the propeller shaft.
Open for suggestions!!
Claes
