Author Topic: Classic from Aero-Naut  (Read 3386 times)
tica
    • Skalamodelskibe
« on: April 13, 2017, 07:53:10 am »
I'm waiting for some small parts for the Möwe II and got a good deal on a Aero-Naut Classic. My wife did build one back in 2013 and I can see that they did update the kit with good things.
1: The wind shield is now fixed in slots in the deck and not just glued to the edge of the cockpit opening.
2: There are now padding and leather for the seat included.
3: There are a few etched details for the instrumentation, steering wheel and step plates for the deck.
4: There are notches at the break off parts that will help in fixing the sides when gluing them in place.
Choice of motor:
I'll use the same set-up as my wife's which is:
Graupner BL Compact 260Z 1380KV with a Graupne ESC 18A FWD and REV. The shaft is replaced with a Robbe 4mm (no 1442) as the one provided is a flimsy part that will not withstand the motor set-up. It will be running on LiPo 2S but if one need a rocket it can run on 3S.
So what is in the box:
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
tica
    • Skalamodelskibe
Re: Classic from Aero-Naut
« Reply #1 on: April 13, 2017, 08:34:46 am »
I have been building for a week.
This is the difference between the old and new version. They have also changed the solid strips of wood with laser cut plywood for easier assembly.
I have tried their suggestion of using painters tape but either it do not stick enough or it leaves adhesive on the wood. So a lot of clamps is the way forward for me.
First piece of the bottom were fixed with ease but the second piece needed some amount of tape.
Daleb
« Reply #2 on: April 13, 2017, 08:41:49 am »
Great start tica, looking forward to following your progress :-))
Cheers Dale.
tica
    • Skalamodelskibe
« Reply #3 on: April 16, 2017, 06:10:51 pm »
Well a lot of things to do that being non model boat related but some progress anyway.
I hope that I'll have the deck on before next weekend.
Drive line in and aligned + glued in place
All supports glued, all joints has been given some 2K glue as reinforcement and the inside has gotten 2 X lacquer and is now resting.
The dashboard has been assemble and had 1X lacquer.
That that for now
tica
    • Skalamodelskibe
« Reply #4 on: October 22, 2017, 08:52:53 am »
Well a bit more progress. Deck has been fitted and the same with some spray rails that is also a upgrade from the first version of the Classic.
Funny thing, I had to do a new stern piece, as it didn't fit and it was the same issue with the other version, either I do something wrong or Aero-Naut is missing a point.
tica
    • Skalamodelskibe
« Reply #5 on: November 13, 2017, 07:55:20 pm »
And now it is all done, just have to wait for some descent weather for a test on the water.
