Rest assured, I am NOT taking a pot shot but you did state
Some ESCs allow you to change switch frequency, which may or may not help.
It most certainly
does help to alleviate by avoiding those frequencies annoying to the human ear. I did extensive proof tests as a due diligence measure before prominently plastering the bold text (on item list number 5, below) on my homepage.
Can anybody else find "frequency change" ESCs that fall within the opening poster's spec and price bracket"? There are hundreds in his county of Kent but manufactured and sold by yours truly.
unbuiltnautilus, you should be finished an hour after closing shop as all you need are the enclosed can Pittman motors, 3 and 5 pole Mabuchi motors in cans of various size.
1) An ESC that "
suffered from the whine from the motors at low speeds" switches
around 3.3kHz 2) You mentioned tenner a time Chinese ESCS. These usually switch at
2kHz.
3) Plenty of older, low frequency speed controls. around frame rate of
50 to 100Hz4) A yellow
no-name brand that
you took for a swim . That one switches around
1kHz but has a
radio fail warning in the form of a modulated chirp on an audible carrier between 3kHz and 4kHz. (You'd think an
audible alert is configured to be difficult to miss, no?)
5) A silvery
no-name brand that lists "
* choice of 4 operating frequencies for smooth and quiet operation" (488Hz, 976 Hz, 1.952kHz & 3.904kHz)
And here are some links to sound samples
523.25Hz 1.0465kHz 2.093kHz 4.186kHz from source
https://en.wikipedia.org/wiki/Audio_frequency
