Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: Smit Rotterdam Build  (Read 37156 times)
FrozenRabbit471
  • Long may you big jib draw
    • My Instagram
« on: April 23, 2017, 05:34:23 am »
Hi all,
I have purchased the Smit Rotterdam as my first boat. I have been warned about the increased probability of disaster because of the lack of experience. You see, this is the first vessel I've ever built.
I figured with the research I've done, the camaraderie on a couple good forums I have and a little confidence, what the heck!
I won't be able to start until after next week. I will convert my daughters old room into a craft room. I have a lot of tools bought to get me started. Over time I'll get more. I'm excited. Here's the first pic to start the adventure.
"a slow and steady steam"
Better to have it and not want it, than to need it and not have it
MartinL
  • Founder member Westham Ocean Racing Yacht Club
Re: Smit Rotterdam Build
« Reply #1 on: April 23, 2017, 07:39:34 am »
All the very best to you in your endeavours, remember not to dig yourself too big a hole before asking for advice, the people on here are brilliant at problem sorting. I will be watching, and learning.
Martin
chipchase
« Reply #2 on: April 23, 2017, 08:47:51 am »
Good luck with your build, as you have said the Smit Rotterdam is not the easiest of kits to start with. my only advice is take your time and enjoy the build. she makes a fantastic model,  :-))
« Reply #3 on: April 23, 2017, 09:05:13 am »
The only thing to fear is fear itself. Thoroughly read the instructions 2 or 3 times before you start, then give it a go. Most of all enjoy yourself.  :-))
T33cno
« Reply #4 on: April 23, 2017, 09:27:15 am »
« Reply #5 on: April 23, 2017, 10:26:38 am »
I've always wanted to build the Rotterdam.  It encompasses all skills needed to make a decent model boat.
I shall be watching with interest and feel you should have no worries, as we will do our best to help you with any problems you may have. Just work on one section at a time and look at it from all angles.
ken
Paul2407
« Reply #6 on: April 23, 2017, 01:39:39 pm »
Great model to build and one I wish I had built from scratch, I've more or less finished renovating one that I bought off ebay and had sat on a shelf for 25+ years it needed a complete overhaul but now looking much better  :-))
look forward to seeing your progress, lots of pictures required please  :}
FrozenRabbit471
    • My Instagram
« Reply #7 on: April 23, 2017, 02:50:20 pm »
Thanks for the support everyone. It helps more than you know. First question, when I do start, and after all the planks are added to the hull, do I use a filler and sand sand it all before applying the fibreglass cloth? The guy at the hobby store said to just apply the cloth right onto the completed planking of the hull. I was kind of surprised. {:-{
« Reply #8 on: April 23, 2017, 02:57:07 pm »
When I built my first POF hull I covered the outside in masking tape (paper type) then used car body filler to fill the gaps from the inside. After removing the tape and fine sanding the hull  I applied the fibreglass and resin.
FrozenRabbit471
    • My Instagram
« Reply #9 on: April 23, 2017, 03:14:40 pm »
Wow. that's an idea. The filler just seeps through from the inside as far as the tape that's on the outside. Sounds like a plan. Anything special for the filler? is there a particular filler that would eat the wood ?
Paul2407
« Reply #10 on: April 23, 2017, 03:49:36 pm »
Just standard P38 car body filler will do and you can get a fibreglass kit in there too you want a fine mesh kit if you can't find in Halfords you can buy this for around £15 on eBay  :-))
« Reply #11 on: April 23, 2017, 03:58:36 pm »
Halfords in Alberta ???
Paul2407
« Reply #12 on: April 23, 2017, 04:00:48 pm »
 {-) {-)  Perhaps they are international now, sorry hadn't noticed your location so your local car spares shop
FrozenRabbit471
    • My Instagram
« Reply #13 on: April 23, 2017, 04:02:21 pm »
Some pics for the startline
FrozenRabbit471
    • My Instagram
« Reply #14 on: April 23, 2017, 07:44:19 pm »
My old tool chest all cleaned up and filled with my new supplies. It's a start. :-))
FrozenRabbit471
    • My Instagram
« Reply #15 on: April 23, 2017, 09:14:27 pm »
I think I'm more spooked on the RC components and accessories such as the lighting etc than the actual build.
I  know the RC and accessories can be expensive, but I get confused on the procedure, placement and proper components required.  Motors, esc's, bec's etc. Should I have a dual / paralell motor / esc set up or just a single. Its a head shaker for me.
I guess I'll have to figure all that out when the hull has been completed.
cos918
« Reply #16 on: April 23, 2017, 10:11:00 pm »
One tip before you start . Is photocopy all the parts . Then you have a set of full size templates in case you need to remake a part
FrozenRabbit471
    • My Instagram
« Reply #17 on: April 23, 2017, 10:17:18 pm »
Holy cow. Very good tip. You wouldn't waste any ink at all if you saved it as "scan to pdf", although the compression of the file may render it off scale on the print when you need it. Best copy to print right away. I'll try it on "light B & W fast draft" and post the outcome. But first, I'm going to spend the day numbering the wood tomorrow.
timbo
« Reply #18 on: April 24, 2017, 07:49:35 am »
Like the idea of a tool chest for storage I could get all my suff in and out of the way.
T33cno
« Reply #19 on: April 24, 2017, 10:09:49 am »
This is where my Rotterdam build started and up to where I shelved it for a while
http://www.motorhomefun.co.uk/forum/threads/going-to-give-myself-a-tug.144750/page-4#post-2190424
FrozenRabbit471
    • My Instagram
« Reply #20 on: April 24, 2017, 06:03:18 pm »
@T33cno I can't access the photo as I don't have an account for that group. Take a screen shot an post it here in this thread. :-))
FrozenRabbit471
    • My Instagram
« Reply #21 on: April 24, 2017, 06:06:47 pm »
timbo, I just did it as a temporary thing, but I like it. haha
T33cno
« Reply #22 on: April 24, 2017, 06:19:37 pm »
It's 9 pages
Just register no need to subscribe
FrozenRabbit471
    • My Instagram
« Reply #23 on: April 24, 2017, 06:26:28 pm »
Will do.
It's 9 pages
FrozenRabbit471
    • My Instagram
« Reply #24 on: April 24, 2017, 06:50:54 pm »
Hi all,
Today is the first day of the build. I have numbered all the parts on the wooden sheets and highlighted each number on the booklet chart.
Next is the reading, then the physical build begins.
Pages: [1] 2 3 4 5 6 7   Go Up
Page created in 0.091 seconds with 22 queries.
