Author Topic: Building a Grampian D-Class  (Read 10300 times)
Re: Building a Grampian D-Class
« Reply #25 on: May 12, 2017, 10:34:18 pm »
Your planking is really nice and neat. I like the bottom, interesting to see a sloping bilge rather than a flat one.
« Reply #26 on: May 12, 2017, 10:39:57 pm »
 %)...chip.....[modern designs!] she has some very unwomanly looking underlines  <*<......but I am sure all true to design and your planking is going at a great rate of knots....what type of wood are you using?
Do you rip your own planks with your PROXXON table saw?
Kim
« Reply #27 on: May 12, 2017, 11:01:08 pm »
Hi Brian,
if it is of interest to you, here is how we do our hulls on the cnc.  Pros and cons for PoF & cnc but as Ballastanksain says the sterns are becoming as complex as the bows.
If it interests you i have posted a very short clip of our prosess of 'cutting' the stern here -
https://en-gb.facebook.com/Clyde-Model-Boats-421996587986355/
Your doing well in a very short time!
Kim
chipchase
« Reply #28 on: May 12, 2017, 11:37:27 pm »
%) ...chip.....[modern designs!] she has some very unwomanly looking underlines  <*< ......but I am sure all true to design and your planking is going at a great rate of knots....what type of wood are you using?
I am using pine and hardwood Derek, to be honest I ripped an old door up for the hardwood LOL. The proxxon is a good saw but the amount of planks that are required it would be a bit much for it, I have a Dewalt bench saw that I used  :-))
« Reply #29 on: May 13, 2017, 02:33:20 pm »
is this the plug for a GRP hull?
desktoprover
« Reply #30 on: May 13, 2017, 06:07:29 pm »
Beautiful work!  I like the planking too.
Blaven03
« Reply #33 on: May 18, 2017, 04:33:39 pm »
Hi, enjoying watching ur two builds, what wood do you use for frames and base and what you cutting with, very very neat. Many thanks
chipchase
« Reply #34 on: May 18, 2017, 08:43:54 pm »
i used 9mm ply for the frames and base, I have a dewalt table saw that i use for the straight cuts and a band saw for the shapes.
chipchase
« Reply #35 on: May 18, 2017, 08:53:52 pm »
A small update,  I am now at the part using the fillers and sanding then more filling and sanding I find this is the worst part of the build.
« Reply #36 on: May 18, 2017, 08:58:55 pm »
Sadly a part of the process we can rarely avoid  :((
Blaven03
« Reply #37 on: May 19, 2017, 08:33:18 am »
Thanks, looking superb.
chipchase
« Reply #38 on: June 12, 2017, 03:11:39 pm »
Here is the latest update on the Grampian plug, i have fitted the belting bars and given her a coat of primer, i find this is the best way to show any small faults that need extra fillers and then more sanding. she is beginning to take shape.
Brian60
« Reply #39 on: June 15, 2017, 09:05:43 am »
Definitely going to be a tough looking ship when she's finished!
desktoprover
« Reply #40 on: June 17, 2017, 06:09:31 pm »
Beautiful!  It looks huge!
chipchase
« Reply #41 on: September 20, 2018, 07:26:02 pm »
First Hull from the mould, the belting bar was remove from the plug before the mould was made, it just did not look right.
