Dear Mayhemmers
I thought that you might like more news from the edge of the world near Farcet and to let you know the latest news from DEANS MARINE.
New additions to the Chandler range of model marine accessories.
PR-805/30 Roller bearing propshafts
This design of Deans Marine P R propshafts are watertight and do not leak any oil. The bearing housing has a bronze self lubricating roller bearing and is sealed with a G ring, the prop end has a brass bearing.
The tube and shaft can be altered in length easily if required as the bearing housing is a separate item.
Tubes are hardened brass WITH A LIGHTWEIGHT 6mm TUBE and shafts are in stainless steel.
PR-55/72 STANDARD BRASS BEARING PROPSHAFTS
This design of Deans Marine P R propshafts are fixed brass bearings at each end of the shaft
Tubes are hardened brass WITH A LIGHTWEIGHT 6mm TUBE and shafts are in stainless steel, threaded M2-M3-M4-M5 with a brass locking ring at the inboard end.
Deans Marine
