I find it interesting that Graupner used to list a 6 volt SLA as an accessory power source for this model, but has now switched to the 7.2 volt NIMH pack. I wonder if it is because the NIMH pack could be used on so many of their other models, including cars ect. whereas the SLA would have limited application.
I tried my spare 6 volt SLA and it appears to provide more that enough power, and probably significantly more than scale looking speed, so I am sticking with it. Besides, I think it will provide significantly increased run times, and it also provides some more of the 16.5 KG ballast required by this hull.
As an aside: The Bluebell model had numerous pin hole leaks along the lines of the bilge keels. At almost 3/4 of a cup/20 minutes, it required attention. Rather than return the hull, I fiber glassed strips of 2" glass tape along the bilge keels inside the hull, as well as adding a strip along the keel line. I also stuffed the bow full of closed cell foam for emergency floatation. It is a very lightly made hull. Quite nice with it's molded in detail, as well as the basic detail of the deck fittings ect. That said, tank testing BEFORE the first sailing is highly recommended.
