Author Topic: new items added to the Deans Marine Chandlers range  (Read 1766 times)
Dean's Marine
    • Dean's Marine
« on: June 22, 2017, 10:48:12 am »
Dear Modellers                         21 /6 /17
 Latest new additions to the Deans Marine Chandlers range of model boat accessories.
      OILER TUBE FITTINGS
Kit for adding oiler tubes to propshafts
Oiler tube and clamp + fixing screws
Clamp around the inboard end of you propshaft screw tight, drill hole through tube,
Allows oiling and greasing of tubes without removing the shaft.
Four tubes sizes
4-6-8-10mm
2 x kits per packet
SHAFT BEARING HOUSING
For the modeller wishing to produce tailored length proptubes and exposed shafts
Inboard end double roller bearing housings fitted with double roller bearings,
 2 x sizes 6mm tube & 4mm tube.
PUSH ROD BELLOWS
 Bellows for allowing push rods through bulkheads and radio boxes for watertight operation.
2 x  lengths 35mm with 6 and 7mm holes fixings
2 x lengths 41mm with 10 & 11mm fixings
2 x per packet
HICO COUPLINGS
For small to medium power models where small size and smooth running are paramount
Available as single and double joint units with plugs in ends from 1mm to 4mm
 Total length of assembled double joint unit is 40mm
DYNACUP COUPLINGS
For medium power models where STRENGTH and smooth running are paramount
Available as single and double joint units with plugs in ends from 2.3mm to 4mm + M4 thread.
 Total length of assembled double joint unit is 60mm
MEDIUM DUTY TILLER ARMS
 Nylon Tiller arms with a brass centre  collet driller to 3mm, Tiller arm fits over collet and is locked in place with a allen bolt. 4 types
 Full details, prices & pictures on our website and online shop in the Chandlers section.
Page created in 0.081 seconds with 21 queries.
